close...but no cigar
Discussion in 'General Maverick/Comet' started by maverick75, Jun 2, 2007.
  1. Maverick6714
    Maverick6714 Member
    Northeast PA
    1970 Ford Maverick, 2004 Dodge Dakota Quad Cab, 1987 Ford Bronco
    I know this doesn't have anything to do with your problem, but I really like your steering wheel. Where did you get it? And what kind is it, if you know?
  2. maverick75
    thanks
  3. maverick75
    Its a gt grant, my uncle gave it to me when he sold his camaro, you can get it anywere they sell grants
  4. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    You're making progress...(y)
  5. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    I'm no expert, but after viewing your vids, I'm even more inclined to believe it to be fuel related now (rather than electrical) - but my Right/Wrong ratio is about 50/50 so take that FWIW. :huh:
  6. Jamie Miles
    Alto, GA
    I've had a few
    I agree, it sounds like you have a fuel delivery problem. It also sounds like it's not fireing on a couple of cylinders, but that may just be your camera making it sound that way.
  7. maverick75
    heres the vid of my uncle trying to start it...
    http://www.youtube.com/watch?v=bHYDmTd64uY
    tomorrow i'm going to fill up the tranny with new fluid and buy the regulator and gauge.
    how much PSI does my holley 4160(6919) need?
    thanks
  8. 74merc
    74merc computer nerd
    1974 Comet
    Whats an easy way to hotwire the car for extended running?
    I started mine this way as the dash is in storage while the car is apart and burned up my Pertronix(I may have jumpered to the wrong post tho, don't remember), so I swapped my points back in. The voltage is dropped to 6v to the coil right? Is there anywhere open in the wiring harness to jump in to use the built in resistor?
    Btw, nearly a year since I started the old girl, fired right up.
  9. maverick75
    Well it fire right up today:dance:
    I put a 1 gallon tank to the fuel line under the drivers door...tuned the carb richer...
    ....but then the carb would not stop squirting fuel even after it died:hmmm:
    While it was running i remembered i left the charger hooked up, and when i went to go see it it was rattleling because of the engine and it almost fell, it would have probably shorted and burned up like my other one did...when i finally unhooked it i couldn't find my screwdriver to adjust the carb(engine was a 4K) when i found one the engine died...
    ....then i found out i forgot to hook up the tranny lines:(
    so what makes the carb squirt fuel like crazy?I rebuilt it about a month ago.
    http://www.youtube.com/watch?v=wgmPN1iOsxs
  10. lilfarley
    lilfarley Chris Comley
    Central City, Iowa
    Btw, nearly a year since I started the old girl, fired right up.[/quote]
    Mine sat for 22 years and all i had to do was splash some gas in the carb and she fired right up
  11. maverick75
  12. maverick75
    Stuck float:slap:
