cluster removal
Discussion in 'General Maverick/Comet' started by mywifeisawesome, Jan 15, 2020.
  1. mywifeisawesome
    mywifeisawesome Member
    Pittsburgh, Pa
    1973 Mercury Comet
    Just saw post yellow75 about needing to remove cluster to get to the dimmer switch. Thank you very much everyone.
  2. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    The dimmer switch is the headlight switch. There’s a button on the bottom of the switch. Hold that button in and it will allow you to pull out the headlight knob and shaft. Then you can use a large Phillips screwdriver to remove the headlight switch bezel. Disconnect the switch from the plug and pull it out through the cluster opening.
  3. William623
    Orlando
    1973 ford maverick grabber
    Are these the ones you are talking about? I already have LEDs but they aren’t dimmable.
    https://www.hipoparts.com/ultra-bright-5-smd-15-led-bulb-194-t-10-wedge-super-wide-angle/
  4. Krazy Comet
    Dismal Swamp
    If it still has the factory radio plug, short the two terminals on connector together. Dash lights should be on any time ign is on. If it blows radio fuse, there is a problem in wiring. If lights are still inoperative, likely the connector on back of cluster has a issue.
    My Comet has been using this connection for last couple years. Damned if I'm taking it apart to repl switch, I could care less if dash light aren't dimmable.
  5. jasonwthompson
    Carrollton TX
  6. 71gold
    "how do you remove the dimmer switch?"
    that would be the last resort...:yup:
  7. Krazy Comet
    Dismal Swamp
    The DIMMER in the headlamp switch is most likely suspect & yes with a bit of finagling, it can be replaced. Down side is a parts switch with good dimmer is required. I fixed the switch in a friend's '72 Bronco which is same as Mav.
    The headlight dimmer on floor has nothing to do with issue.
  8. mywifeisawesome
    Pittsburgh, Pa
    1973 Mercury Comet
    The cluster has to be removed to get the dimmer switch out right? If so how do you detach the speedo cable unhooked from the rear of the cluster? I played with it some today,could not remove, that being said I'm not sure how to remove it. Thank you everybody. Also, is there a fuse for the dash lights? I replaced all my bulbs today. still no speedo light
  9. 71gold
    there is a plastic cup on the end of the cable. it has two ears that hold it onto the speedometer head. most likely the ears will break off .
  10. Krazy Comet
    Dismal Swamp
    Yes the shortest fuse in box is for dash lights.
  11. Acornridgeman
    Wisconsin
    This will tell you all about getting the cable off ----- with pictures too ……….. :cheers:
    http://mmb.maverick.to/resources/instrument-cluster-speedometer-cable-release.115/
  12. mywifeisawesome
    Pittsburgh, Pa
    1973 Mercury Comet
    Wow, thank you very much for all the information. I really appreciate it. Everyone on here is awesome! I'll keep you posted.
  13. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    It appears your wife is awesome also! :biglaugh:
  14. mywifeisawesome
    Pittsburgh, Pa
    1973 Mercury Comet
    Yeah she set this up for me and surprised me with that user name. lol
  15. mywifeisawesome
    Pittsburgh, Pa
    1973 Mercury Comet
    Hey everyone, when you remove the speedo cable from underneath mine was attached to the floor with a p clamp and a metal clip,fastener of some sort, needless to say it's rusted. does anyone know if you can buy those new? Thank you
