Clutch Cable Swap
Discussion in 'General Maverick/Comet' started by Ken Thompson, Nov 30, 2008.
  1. jeremy
    jeremy I build t5's
    Corona, Ca
    the only setups I've seen are the normal ones that use a cable that adjusts at the fork, or a setup that adjusts at the firewall.
    the oem mustangs have the plastic quadrant setup that adjusts by pumping the clutch pedal..but it's a trashy setup
  2. mean_maverick
    my adjustments are made on the bellhousing. ive had this setup in my car for the last 6 months or so with no issues or anything. im not saying i have the best setup but so far it has worked out really well.
    and i think that the mustangs were the only thing to have the quadrent adjusting setup, that ive ever seen...
  3. Earl Branham
    Lugoff, SC
    I have the Mustang Steve kit in my car. Works great!
  4. mean_maverick
    thanks for the input. i was looking at the setup today and was wondering about it's form and function. i tried to fab up my own quadrant but could never get it to make enough tension. my brother will prolly swap a T5 in his Comet GT down the road so that might be a direction he wants to go in (if he doesnt make me do it for him :rolleyes:)
  5. Craig Selvey
    I had a Bobcat (Mercury's version of the Pinto). I always had a problem with the cable pulling THROUGH the firewall. Finally dedicated a set of vice-grips to the cause and it cured that problem.
  6. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Sounds like me. I shudder at the thought of a cable...
    I have a 78 Chevy with a cable. No matter how well we reinforce the firewall (short of replacing it), it keeps ripping it.
    The cable is tough as nails, I doubt it will break.
    Having had several modern cars with hydraulic setups, I fell in love with that system. The hydraulic TO is even more sweet since you only have to run a single hose into the bell and do away with all that linkage.
  7. bmcdaniel
    At first with the Pinto the cable bent, then finally broke through, the firewall. After reinforcing the firewall I started breaking off the little swedged-on balls on the ends of the cables.
  8. Ken Thompson
    Ken Thompson Member
    Kennesaw,GA
    Thanks for all your insite:thumbs2:. I never realized a T-56 was so large. Back to the T-5 idea.
  9. Earl Branham
    Lugoff, SC
    Haven't had a problem with mine. Been on for about 2 yrs.
  10. maverickmatt84
    maverickmatt84 Member
    missouri
    76 mav
    t-56 swap
    i have put a 03 cobra t-56 in my mav.it wasnt that hard,cut the trans tunnel and brace for the transmission.i raised it about 2 inches.as for the bellhousing i used a mcleod unit,it cost about 450.00.when i get enough money im gonna go with a hydraulic setup like this one http://store.summitracing.com/partdetail.asp?part=MCL-14005-30&view=32&N=700+4294925134+400374. its not cheap but theres not much room there for a throwout bearing arm and i like the feal of the hydraulic clutch pedel.i have one pic of the transmission tunnel on here i will try to get more posted.[​IMG]
  11. mean_maverick
    id like to see some more pics and info on ur swap as well :)
  12. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
