Clutch Pedal Assembly
Discussion in 'Technical' started by gsuders, Apr 27, 2019.
  1. gsuders
    gsuders Member
    Keymar, MD
    1970 Ford Maverick
    I got this clutch pedal assembly in a box of parts with my Maverick. Can anyone tell me is this correct for a Maverick. If it isn't any idea what it fits?
  2. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    Looks like the Maverick setup to me.
  3. Acornridgeman
    Wisconsin
    I agree - Maverick set up
    Looks to be missing the red clip and the spring
  4. dyent
    dyent Member
    vancouver bc
    and the Assist Spring bracket that bolts to side of pedal assembly bracket, very difficult to locate..........
    David
  5. Krazy Comet
    Dismal Swamp
    I don't see any reason the spring for a small block Torino, Mustang cannot be used.
    C80Z-7534-B listed in Master Parts as 3.5" (big block spring is 3.75")
    Spring for Maverick D0DZ-7534-A, length 3.53"
    https://www.cjponyparts.com/clutch-...5F0HlegjvXqQTuyXclgbLfCdQMUY7bJRoCXOwQAvD_BwE
  6. dyent
    dyent Member
    vancouver bc
    P1020050.JPG I was referring to the "assist spring bracket", which mounts to the pedal support bracket on the side, not the spring.....
    David
  7. Acornridgeman
    Wisconsin
    Hopefully these missing pieces are in the box that had the pedals.
  8. rthomas771
    I'm not using the clutch pedal assist spring since I’m using a diaphragm style pressure plate with my t5. It would be a different story and maybe two feet if using the factory 3-finger style
