Clutch Pedal Removal
Discussion in 'General Maverick/Comet' started by smegnl, Dec 9, 2019.
  1. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
  2. dyent
    dyent Member
    vancouver bc
    Here is picture of Brake and Clutch Pedal assemble, there is a red clip that has to be removed and then Clutch Pedal/shaft can slide out. You have to disconnect the clutch rod and brake rod linkage and carefully remove the blue assist spring, before sliding out the Clutch Pedal/shaft.......
    David
  3. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Thanks. This helps. Can I then put the break back in?Or will there not be the mounting gear for the left side of the brake?
  4. dyent
    dyent Member
    vancouver bc
    So you just want to remove the Clutch Pedal and then just install the same Brake Pedal? If so, you would have to use a 5/8" bolt/nut to secure the Brake Pedal to the support bracket and use same nylon pedal/shaft bushings (4)........
    David
  5. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Couldn't he just use the pin from an automatic setup? I'll have to compare mine tomorrow after work.
  6. RMiller
    Kennewick, WA
    After thought....you would do well to swap to the auto setup and sell your manual parts, there's more demand than supply!
    Craig Selvey likes this.
  7. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Anyone want to trade an Auto set up for a manual set up?
  8. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    I dont have an auto set up.
  9. dyent
    dyent Member
    vancouver bc
    Some shafts on the automatic where 3/8" diameter and others where 5/8" diameter, so he would have to make sure to get the correct 5/8" one for his support bracket.....
    David
    RMiller likes this.
  10. dyent
    dyent Member
    vancouver bc
  11. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
  12. Craig Selvey
    I would trade you.
  13. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Let me see what the other guy says since I already reached out to him. Ill give you a yell if not. Id be willing if you paid shipping both ways or such.
  14. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Other guy isnt interested. Says he doesnt trust internet strangers, which is fair enough. PM me if your interested still.
  15. Craig Selvey
    Would be best to email me (see below). I am not on here enough to catch all my PM's in time.
