Coil spring insulator
Discussion in 'General Maverick/Comet' started by Chlorin8ed, Mar 3, 2018.
  1. Chlorin8ed
    Chlorin8ed 72 Comet
    Iowa
    1972 Mercury Comet, 1980 Chevy Malibu, 1987 Chevy R10
    Just finished putting in the passenger front coil spring back on. Noticed the coil insulator on top is NOT in the correct position. :-( This spring was way harder to get in than the driver side. Besides me being picky, and thinking I was already lucky just getting the spring in without killing myself, does it really matter? It is on the spring, just not in the correct position....
  2. Chlorin8ed
    Chlorin8ed 72 Comet
    Iowa
    I tried two more times to get it moved. It is going to stay where it is at :-(
  3. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Sounds like you are doing this without a spring compressor if you are struggling with it. If that is the case, head down to Autozone and use their tool rental program. With it you can position all the pieces and let of the tension when you have it where you want it
  4. Chlorin8ed
    Chlorin8ed 72 Comet
    Iowa
    Nope, I was using a spring compressor. I tried 3 times on the passenger side and gave up. I compress the compressor all the way. I had to spin the coil to get it fit and that is must be with it slid off a little.
  5. RMiller
    Kennewick, WA
    Wow, sounds like fun then! I guess I'll get to see what you are up against this summer as I assemble my suspension, right now I have 4x4's in there to hold it up and those went in easy!!:rofl2:
  6. Krazy Comet
    Dismal Swamp
    With a tool that compresses spring to point it just sets back in place, not a issue... I didn't have any problem with insulators on my Comet and I've had two different sets of springs installed...
  7. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    You are supposed to tape the isolator to the top of the spring with black electrical tape.
    mojo and yellow75 like this.
  8. mojo
    I had a similar issue doing my spring insulators on the drivers side. I had a pretty ruff time getting it in the correct position. I wound-up removing spring a few times to get the insulator in the proper position. I didn't think about taping it to the spring. I think the longer (taller),springs make getting the spring in the saddle more difficult.
  9. Chlorin8ed
    Chlorin8ed 72 Comet
    Iowa
    Probably should have taped it. These were stock springs but I did change spring perches. I am guessing I just didn't get the right combination/position of the compressor this time. BTW the Scott Drake perches dont look like roller percher's but they act like one You can spin the bushing all the way around. :)
