Coil spring isolator
Discussion in 'Parts Interchange' started by Hairy W Bush, Mar 9, 2019.
  1. Hairy W Bush
    Hairy W Bush Member
    Palm Coast, Fl
    1972 Maverick Grabber
    I'm looking for a set of the isolators to that sit.up top of the coil springs. I want a polyurethane and I can't find that for the Maverick but I did find a set for the 65-73 mustang. Will those fit?
  2. dyent
    dyent Member
    vancouver bc
    Yes, they should fit.
    David
  3. Hairy W Bush
    Hairy W Bush Member
    Palm Coast, Fl
    ok what about the spring perches?
  4. dyent
    dyent Member
    vancouver bc
    Where you looking at replacing the rubber pads on the spring perches too? AFAIK, there are only the rubber pads on the perches and I do not know if you can just purchase them separately.......if the pads are worn on your perches, I would suggest purchasing new spring perches! OEM replacements are pretty inexpensive or you can upgrade to ones having "poly" type bearings which apparently act just like "rollerize" type perches, only much cheaper. I can't remember off hand who makes those "poly" type, but another member had posted, so you could probably do a search and find it.
    David
  5. Hairy W Bush
    Hairy W Bush Member
    Palm Coast, Fl
    yea I need to replace the whole thing. i actually found a listing that shows it fits mustang and maverick so i'm good. I'm going to do a little upgrade on the material. thanks!
  6. dyent
    dyent Member
    vancouver bc
  7. Hairy W Bush
    Hairy W Bush Member
    Palm Coast, Fl
    yea no need whatsoever for a roller. i just want it to last so I'll be getting the other one
  8. dyent
    dyent Member
    vancouver bc
    I thought the price difference between the two would be much more than $70 for something that will last a lifetime....
    David
  9. Hairy W Bush
    Hairy W Bush Member
    Palm Coast, Fl
    That's alright... I still need to buy a mirror on top of of all this and I can't get them cheap.
  10. Hairy W Bush
    Hairy W Bush Member
    Palm Coast, Fl
    Hey by the way what coil spring compressor do you guys use? I used this Evertool 67050 I rented from O'Reilly's and it took way too long. With the way you're supposed to use it you can't get even a ratchet to it. is there one I can just take an impact to the damn thing from the top? Sorry I probably need to make a new thread somewhere.
  11. dyent
    dyent Member
    vancouver bc
    This is compressor I have...........
    David
  12. Hairy W Bush
    Hairy W Bush Member
    Palm Coast, Fl
    maybe that will work better. what's the purpose of that spacer?
  13. Krazy Comet
    Spacer is on top, gives less bolt to interfere on spring perch.
    Many compressors have a assortment of spacers.
  14. Hairy W Bush
    Hairy W Bush Member
    Palm Coast, Fl
    Gotcha. I'll see if that one is available to rent
  15. Hairy W Bush
    Hairy W Bush Member
    Palm Coast, Fl
    hey what's a good length for that tube spacer? I need to use the saw at work before the weekend!
