Coil Spring Pad
Discussion in 'Technical' started by Wilsond3010, May 17, 2013.
  1. 71gold
    ...:hmmm:...
  2. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Would this have anything to do with post #6?
  3. mrmalina99
    mrmalina99 Member
    Belfair, WA
    1973 Maverick
    No, my springs are on correctly.
  4. injectedmav
    injectedmav Member
    Georgia
    The fittings didn't fit mine since I did the Arning UCA drop with the stock UCA's.
  5. Mad Goon
    Mad Goon Scaring the Hondas
    Redondo Beach, California
    Did a 1" drop on mine... Had to bang the hell out of the inside of the shock towers to get the grease fittings to clear.
  6. 71gold
    were they the fittings from... Scott Drake...or just regular 90 degree fittings ?
  7. injectedmav
    injectedmav Member
    Georgia
    Mine were Scott Drake.
    I originally relocated the UCA'S 2" down and 1/8" back per the ProMotorsports Engineering kit with the wedges. I "massaged" the towers and got 3 of them close to fitting but the one in the left side back wouldn't go due to the steering box notch, so I stopped the beating. They may fit with the 1" drop I have now but I have tubular Street or Track UCA'S anyway. If I ever put the stock arms in again, I'll do the rubber bushings instead of the metal shaft kit.
  8. Wilsond3010
    Wilsond3010 Member
    Regina, SK
    1970 Maverivck
    I need to not let these springs defeat me. I tried off and on for about 4 weeks trying to get the springs in and every time I compress the spring if I get it compressed enough to on into place then there is too much of the tool sticking out the bottom and it's hitting the a-arm
    really can't figure what am missing
  9. dyent
    dyent Member
    vancouver bc
    can you post a picture so we can see the problem........then a few of us may have a solution for you! :)
  10. groberts101
    groberts101 Member
    Minneapolis, MN
    sounds like you have the wrong tool for the job. ;)
  11. Wilsond3010
    Wilsond3010 Member
    Regina, SK
    1970 Maverivck
  12. blugene
    blugene Senior member
    A better pic of the spring on the seat would be nice.. Mine have a stop that is on the inside towards the frame. The spring end almost touches it.
  13. dyent
    dyent Member
    vancouver bc
    first one is only for MacPherson strut coil springs, to use them on our coil springs is very dangerous!
    second one is the correct coil spring compressor, like it was mentioned earlier, if you can get a few pictures, then perhaps we might see what the problem is and help you out......global warming, eh?:huh:
  14. 71gold
  15. 71gold
    is that ... shield on right...:hmmm:
