cold start
Discussion in 'Technical' started by johnson, Dec 5, 2009.
  1. random hero
    random hero 1972 ford maverick I6
    hudson valley
    1972 maverick
    try adjust the choke on the carb, just 2 screws and u turn the black cap to rich or lean out the choke, for colder starts u want to richen it a bit, mine is set a few marks past the center point...give that a shot hope it helps. i have about the same setup as you(duralast gold batt, points, 200i6)
  2. johnson
    johnson Member
    fargo, ok
    69.5 maverick
    thanks. i'll do that on lunch break.
    whats the Pertronix part number you're using?
  3. scooper77515
    Hmmm. I don't have the part number. Just look for the Pertronix Ignitor at the local auto parts store.
  4. johnson
    johnson Member
    fargo, ok
    69.5 maverick
    are you talking coil pack or distributer?
  5. scooper77515
    It is just a points replacement. You unscrew the points and throw them away. You screw down the pertronix unit which has 2 wires coming out of it and out of the distributor.
    Then there is a little plastic sleeve for going around the distributor shaft under the rotor. The sleeve has little magnets imbedded into it, I think, so as the magnets rotate around with the rotor, it triggers the electrical signal.
  6. baddad457
    You need the 6 banger unit. Scooper's got a V8. Not the same conversion module.
  7. Positively Ralf
    Yonkers, NY
    1974 Maverick
    For the i6, the Pertronix part you want is #1261. Also, if you have a pre 74 car, you may want to upgrade the coil.
