Column Shift linkage
Discussion in 'Technical' started by mgrodsky@q.com, May 31, 2010.
  1. bomrat
    bomrat Member
    North Little Rock, AR
    74 Comet 4dr 347 4r70w
    the ecu for the engine/trans is the eec-V so i am going to use a tweecar r/t to program the engine and trans.
  2. runeking40
    runeking40 Member
    Illinois
    1973 maverick
    well hey guys i have a c4 ans headman 88400 headers and the auto shift linkage doesnt fit the v8. so what do i have to do. because i thought with shorty headers i could keep the mechanical shift linkage. are i-6 different than v8s.
  3. cjtorinoman
    cjtorinoman Member
    chesapeake va
    You can convert a v8 column linkage to a single down rod to the trans from the column pivot and it works flawless you completely eliminate the bell crank pivot did it to my 72 Comet. Lokar makes a kit to do it very easy if you have some fabricating skills now working on a ratcheting column based shifter with all factory appearances!!!!!!
  4. runeking40
    runeking40 Member
    Illinois
    1973 maverick
    well i am wondering im sitting here not knowing what to do.
    ok is the v8 and i-6 linkage different?
    and if i have a 1979 ltdii column shift could i take it off that
  5. topcat
    topcat Member
    Essex, England
    '71 Grabber 302
    I'm in a similar boat- I think the linkage was missing when I got my car but I definately want to keep the column shift, is it easy to convert to cable? I can do most things myself no probs, but never worked on an auto before! I also want some decent headers which I gather dont fit with rigid linkages.
  6. Craig Selvey
    Yes....the linkage is different from a 6 cyl to a V-8.
    I doubt the LTD stuff will work.
  7. runeking40
    runeking40 Member
    Illinois
    1973 maverick
    so where can i get a v8 linkage?
  8. Craig Selvey
    Put an want ad on here.
  9. Jdb
    Jdb Member
    California
    71 maverick 2 door
    Hi can you post a picture of that linkage setup thanks
  10. Jdb
    Jdb Member
    California
    71 maverick 2 door
    do you have the picture of the modified linkage?
  11. Jdb
    Jdb Member
    California
    71 maverick 2 door
    this is the diagram from ford.
  12. Jdb
    Jdb Member
    California
    71 maverick 2 door
    Hi any info on how to make this work, appreciated.
  13. Jdb
    Jdb Member
    California
    71 maverick 2 door
    I only have the diagram, hard to find that v8 linkage mustang or falcons might work.
  14. Jdb
    Jdb Member
    California
    71 maverick 2 door
    Can you post a pictures of that pls greatly appreciated thanks
  15. mvw66gt
    mvw66gt Member
    Arthurdale, West Virginia
    71 Comet GT
    I think I've got a set of the V8 column shift linkage that I don't need. PM me if your interested. - Matt
