Column shift safety question
Discussion in 'General Maverick/Comet' started by satchelmcqueen, May 25, 2019.
  1. krelboyne
    krelboyne Remember
    Salem, Oregon
    The part with the arrow is what locks the steering wheel. Here is a picture of that part. The pin can be removed by removing the "E" clip. You can not remove the whole gear thing, because that is what engages your ignition switch on the top of the column. I believe that the pin is spring loaded.
    The tab at the bottom of the steering column, has a rod attached that locks the transmission.
    Crazy Larry likes this.
  2. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    I have been watching and thinking this is being over complicated but boy was I wrong! I have done this to a GM but not a Ford and they obviously work in different ways. I went out and knocked the pin out of my lever and sure enough, the collar does not stay in park. Learn something new every day whether we want to or not!!!:biglaugh:
  3. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Or in my case, it's been so long since I've worked on this stuff, I start second-guessing myself.
    RMiller likes this.
