column shifter knob
Discussion in 'General Maverick/Comet' started by wolfheads, Apr 29, 2017.
  1. wolfheads
    wolfheads MadMav
    Florida
    73 Maverick / 2000 Harley Low Rider
    Has anyone removed the knob on a column shifter? If so, what's the easiest way of doing it? I'm thinking about replacing the shifter knob on mine.
  2. Acornridgeman
    Wisconsin
    I don't think the shifter knob comes off the column shifter. The entire lever is one piece.
  3. wolfheads
    wolfheads MadMav
    Florida
    The column shifter on my 73 has a plastic knob and a metal arm.
  4. Acornridgeman
    Wisconsin
    I just looked at one and you are right. Looks like it is 2 pieces, 1 metal and 1 chromed plastic. I tried to see if it was threaded but it would not budge. Maybe if someone has an old junky one they could tear it apart to see if it is threaded or a press fit. I looked at both column shift auto and manual shift and they both had a plastic knob end.
    Interesting ......... :yup:
  5. wolfheads
    wolfheads MadMav
    Florida
    I'm sure it's pressed on there or molded on. Just wondering if anyone had removed the knob and what level of difficulty they had, if any. I noticed online that they sell the factory style knob for around $12, so it is replaceable.
  6. Krazy Comet
    AFAIK lever end is splined so is pressed on, but not meant to be removable... Fairly sure the end wasn't serviced by Ford...
    Either cutting, compressing in vice, or simple ole BFH on the plastic should produce results(yeah you'd need to remove lever on second two options)...
  7. Mavman72
    Put the arm in a vise(Or leave it attached to the column)...Heat the knob with a heat gun...Big pair of channel locks/pliers around the knob...Twist/wiggle and pull...Works every time....Its kinda swedged/bonded on there.
    stumanchu, Krazy Comet and BKelley like this.
  8. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
    If you replace your plastic knob with the D3OZ chrome plated metal knob on an automatic shift lever, be sure to remove about a 1/16th of an inch from the end of the lever or the knob will not fully seat to the lever.
    jasonwthompson and Krazy Comet like this.
  9. stumanchu
    stumanchu Stuart
    Portland, OR
    Nice! Does this trick work for the turn signal plastic end?
  10. Mavman72
    Yes... it will.
  11. 71gold
    Twist/wiggle and push it back on...:huh:
  12. Krazy Comet
    That's what she said... Or was it in?
  13. wolfheads
    wolfheads MadMav
    Florida
    Finished product.
  14. stumanchu
    stumanchu Stuart
    Portland, OR
    LOL.....that is not what I was expecting to see, but the color looks good!
