Column to Floor shift swap completed!
Discussion in 'Technical' started by dmhines, Jul 22, 2005.
  1. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Great! Thanks Allan ...
  2. dmhines
    Cumming, GA
    I just pulled the car in the garage and found out I have some adjusting to do .. the reverse lights come on in neutral instead of reverse ..
  3. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    Mustang-IIs and Pinto indicatiors work on those as well...
  4. 74merc
    74merc computer nerd
    1974 Comet
    waitaminute, did TL just comment about a Pinto part??
  5. dmhines
    Cumming, GA
    Cool ... sounds like I have a pretty good chance of finding one then ...
  6. Craig Selvey
    I was thinking somebody was repopping those indicators?
  7. dmhines
    Cumming, GA
    I searched every Mustang place I could think of ... nobody has them that I could find ... :(
  8. Craig Selvey
    I thought I saw one......but I can't find it now. I bought one off ebay years and years ago.
    The bushings are available though.
  9. dmhines
    Cumming, GA
    I know the shifter bushings are available ... mine seem fine.
    I thought there should be a bushing on the end of the rod where it connects to the lever on the tranmission but none of the Ford diagrams I have show a bushing ..
  10. dmhines
    Cumming, GA
    Craig ... I will get those Magnum 500's on one of these days as well! :)
  11. T.L.
    T.L. Banned
    Southern Colorado
    Hey Dan, what type of switch are you using for the back-up lights?..
    BTW: That keychain is the exact same one that I have my Maverick keys on...(y)
  12. dmhines
    Cumming, GA
    With the custom lever Ed made me I left the rod connect to the steering column. When I shift on the floor the collar on the column also moves. So the reverse lights and neutral safety all work as before. I have to adjust the linkage to the steering collar so the reverse lights come on at the correct time .. it's off by about 1/4 inch or so ..
  13. T.L.
    T.L. Banned
    Southern Colorado
    The problem with that is you can't mount a tach on the column. That's why I disconnected all the column linkage on mine. I still need to figure out how to make my backups work...
  14. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    dan, i was thinking what about a grommet on each side of the adapter? just a thought
  15. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    T.L. are you saying you can't mount a tach on the column with a column shifter? :confused: I had a tach on mine with the column shift still hooked up. Unless you mean mounted with something other than the standard hose clamp? :D
