Column to Floor shift swap completed!
Discussion in 'Technical' started by dmhines, Jul 22, 2005.
  1. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Yeah ... a really big grommet ..
    What is the diameter of the large hole in your adapter? I'll check Home Depot tomorrow for something usable but don't feel like pulling it back apart to measure the hole ... :)
  2. dmhines
    Cumming, GA
    Hey T.L. Are you positive a Mustang II shifter will have the same clear pointer? I also need the black curved band that goes beneath the pointer and gives the lenses a black background. Would that be the same as a Mustang II? The Mustang II bezel seems to be the same or similar in size ... not small like the early Mustangs.
  3. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    the hole is 3/4". i checked my mustang II shifter could not find a part number, looks the same though.
  4. ronr11
    ronr11 Member
    hartsville sc
    71 maverick
    Hey Dan Just Done This And Used A Pinto Indicator But The Blue Plastic That Dims The Bulb Was Gone/broke So I Took A Green Turn Sig Indicator From An Ol Dash And Cut It To Fit Looks Good To Me
  5. ronr11
    ronr11 Member
    hartsville sc
    71 maverick
    I Also Used A Switch That Bolts To The Trans Housing And It Has A St &backup Lites In It
  6. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    The ones I've seen appear to be the same. I can't bet my life on it but I think they are all identical. The Mustangs and Torinos had a curved shifter, while those on Mavericks, Comets, Mustang-IIs, and Pintos were straight, but internally, it's all the same stuff (from what I've seen)...
  7. dmhines
    Cumming, GA
    Thanks for the info guys ...
  8. dmhines
    Cumming, GA
    I am also missing the black curved piece that goes beneath the shifter indicator arrow. Would one out of a Pinto work or is it gonna be smaller? Here is the picture of a pinto shifter ....
  9. fan2488
    fan2488 Member
    spring,TX
    the pinto shifter looks the same as mustang II. i will check today.
  10. Earl Branham
    Lugoff, SC
    Dan; I have a Pinto shifter, let me look.
  11. dmhines
    Cumming, GA
    I know the black piece that curves below the shifter should be approximately 6 inches or so long ...
  12. fan2488
    fan2488 Member
    spring,TX
    i checked today,the black peice is too short.
  13. dmhines
    Cumming, GA
    OK thanks ...
  14. dmhines
    Cumming, GA
    I won an auction for a $25 shifter on eBay with the parts I need ... thanks to all those that looked for parts for me. Turns out they are not that easy to find and some of the Mustang Houses wanted $50 just for the two pieces I needed ... :(
    For those buying a used shifter make sure it comes with all the peices!
  15. T.L.
    T.L. Banned
    Southern Colorado
    Glad to hear you got everything you needed, Dan...
