Combo's
Discussion in 'General Maverick/Comet' started by cityboy, Jun 2, 2003.
  1. Lightning
    Lightning Member
    Saskatchewan ,Canada
    1971 comet GT
    2450 lb car (no driver)
    victor junior intake
    750 mechanical
    69 windsor heads custom ported by some loser callede 'ME'
    1.92 x 1.60 valves
    276 x 268 degrees duration at .050 6.80 lift
    valve timing advanced 4 degrees
    11.5 TRW pistons ( about 10.3 with 60 cc chambers)
    stock rods with 5/16 aftermarket bolts
    stock crank
    an old mexican marine block
    A1 5000 stall ( a little too small )
    stock 5 by 5 by 5 C6 transmisson
    5.13 gears
    stock suspension more or less but tubbed
    11.20 to 11.50 at 118mph at 1680 feet
    Streetable where I live but may not be so where you live . LOL.
  2. Purple70
    Purple70 Member
    Dayton Ohio
    the mph was 133.47 and the time was a 9.997 to be exact :)
    (1/8 mile best was a 6.34@108.72 i cant wait to try a 4.86 for a better 1/8 mile time :))
    and yes it has a 10 point cage i havent certified it yet just cause i think im gonna chill out a little before i break something lol...
    and the weight with me in it is right at 3100lbs...
    your set up sounds pretty impressive too, you gonna make it to the Round Up this year?
  3. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    I'd have to trailer it
    and survive off of
    plaque for another
    6 months to make it! :D
    Also, I just bought a new
    Holley Systemax II upper
    and lower intake, professionally
    ported - 665 pesos! :eek:
    (thus the plaque diet).
    It's supposed to optimize
    the solid lifters set-up.
    :hope: :hope: :hope:
    Great mph, btw.
    And yes, I'd say to look
    for a couple of tenths at
    least
    from the new gears!
    Jeez! It's gonna scream!
    Good luck,
    Rick
  4. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    Dennis
    If you want, at the round-up you can use my slicks to make a pass and see how it helps!
  5. Mavaholic
    Hey John, if they will fit under my metal, I'll take you up on that offer.
  6. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    They should fit with no problem. I had them on my 75' and it was a little close to the fender well, but it did clear and your Sprint sits alot higher than the 75' does.
