conecting subframes
Discussion in 'Parts Interchange' started by cometguy1971, May 16, 2014.
  1. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    I don't see the point of bolt-on frame connectors, considering how thin the metal of the sub-frames is on these cars.
  2. Dave B
    Round chromoly, would be stronger than what you would be tying together..
  3. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    I too would rather weld them on. Perhaps the bolt on pieces could be welded on.
  4. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    So would DOM tubing lol perhaps even HREW
    I just brought up tubing is stronger in all directions = better overall if you dont know the direction of bending force..
    I atually haven't really seen many tubular SFC and mavericks only have like 2 or 3 off the shelf square tube SFC available..so, doesn't really matter much unless he's going custom
  5. 71gold
    you need more of a fabrication Guy than just a welder... :yup:
  6. cometguy1971
    cometguy1971 Member
    painesville ohio
    1971 mercury comet
    thanx everyone for info..looks like i need a fabricator
  7. cometguy1971
    cometguy1971 Member
    painesville ohio
    1971 mercury comet
    thanx again everyone i found a fabricator.....how do i post pics?
  8. wardf
    wardf Ward Frahler
    Elizabethtown, Ky.
    70 maverick
    I just posted a set of subframe connectors in the classifieds. They were made by a member here and worked very well for those who installed them. Might be able to do a search and find them installed.
  9. bmcdaniel
    I have bolt-ons and they made a noticeable difference in stiffening the car. The rear of the bolt-on connectors wrap around and bolt to the leaf spring eye so it's a pretty solid connection. In the front I added extra bolts so that they connect to about a foot of the front subframe. Bolts are installed vertically and horizontally so they don't move in any direction. This was before I owned a mig welder so that's how I had to do it.
  10. mojo
  11. CaptainComet
    Check out the way Frank did his .... He used Chassis Engineering connectors, but modified them by raising them up. They pop through the floor and his rollbar mounts directly to them. This gains a bit of ground clearance, but more importantly, is a stronger install because the floor pan is now welded to them too ... see the picture in post 138.
    http://mmb.maverick.to/showthread.php?t=91278&highlight=subframe+connectors&page=14
  12. cometguy1971
    cometguy1971 Member
    painesville ohio
    1971 mercury comet
    the threw the floor pics look great..looks like i got lots of work.i just started a new job so cant get days off to go to gathering..would love to go .does any one know if a 68 thunder bird 9in rear end would fit a 71 comet? its a "n" stamped and has 31 spline axles
  13. Craig Selvey
    It will take quite a bit of fabrication.
  14. cometguy1971
    cometguy1971 Member
    painesville ohio
    1971 mercury comet
    what parts transfer over
    hello guys does anyone know what ,if any disc brakes on front of another car transfer over to a 71 comet?i would also like 5 lug front hubs and axles also can anyone point me in right direction?
  15. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    This thread is about subframe connectors, not brakes.
