Consolette cost?
Discussion in 'General Maverick/Comet' started by William623, Sep 6, 2015.
  1. William623
    Orlando
    1973 ford maverick grabber
    image.jpg I picked up an assortment of goodies today at the Webster car show including a maverick Consolette with a clock. I'm just curious what is a good price for one of these in good condition? I'm planning on putting it in my car but I was just curious.
    Comet Fever likes this.
  2. tody
    tody Member
    cologne, germany
    if memory servers correctly, prices were in the $200 region...
  3. William623
    Orlando
    Thank you, seems that I did pretty well price wise on mine then.
    maverick1970 likes this.
  4. mav1970
    Does the clock work?
  5. Krazy Comet
    Probably not since 1972...
    JoeB likes this.
  6. William623
    Orlando
    I have not checked it yet, but the previous owner stated it did. Just had to remove when he installed a shifter. Is there a way to check with out power?
  7. William623
    Orlando
    It is from a 70 maverick, there is only one small crack easily repairable. I also got an extremely good condition comet deluxe gas cap for five bucks, a small bumper supports for 10 and a hump hugger console today!
  8. William623
    Orlando
    I was considering making a removable block off plate and install a better clock, most likely a digital one. But I will definitely test that one!
  9. Krazy Comet
    The movement is cheap and along with the heat/cold and vibration in a automobile, after a couple years they rarely kept time... After three or four years, were generally dead...
    The clocks have a "auto wind" mechanism that consists of a electrical contact on a arm(similar to a relay) that closes as the main spring unwinds... When the contact closes, a electromagnetic coil kicks the arm so it rotates approx a half turn, which tightens the main spring and the process repeats... Problem is they have to rewind approx once every 60 seconds or 60 times in a hour, 1440 times a day, 10080 times a week, 525,600 times a year -- well you get the picture...
    Would be interesting to retro fit a modern AA battery movement into one...
  10. Cruzin Illusion
    Cruzin Illusion Enigma
    Commerce City, Colorado
    1972 Grabber
    I have a NOS consolette with clock if anyone is interested. Brand new never been put together or hooked up.
  11. Cometgt_71
    Cometgt_71 Member
    Saskatoon, Saskatchewan, Canada
    71 Comet, 2 72 Comet GT's , 73 Comet GT, 77 Maverick
    I remember an old auto krafters catalogue that offered a quartz clock conversion for those, if I'm not mistaken.
  12. z28th1s
    Lynchburg, VA
  13. William623
    Orlando
  14. 71Mavrk
    71Mavrk Member
    Nevada
  15. William623
    Orlando
    That's was actually pretty helpful, luckily mine still looks pretty good. I just have to figure out how to make a block off plate.
