Control Steering Valve
Discussion in 'Technical' started by Mlover, Sep 16, 2017.
  1. Krazy Comet
    Dismal Swamp
    Only adjustment is centering the control valve...
    All that's required is tightening nut till it begins to snug up, then back off ΒΌ turn... There is a notation in shop manual to be sure nut actually turns on bolt the full amount, will be maybe 1/32" rotation before nut loosens... A inch pound figure is given to hopefully prevent the ham fisted from over tightening, possibly bending/breaking the stop pin...
    When I did my first one my work bench looked like the exploded view in shop manual... Each part in exact order...
  2. Mlover
    Mlover Member
    Bay Area
    Ford Maverick 1974
    Thanks for the information! Just went out to get a inch wrench. I noticed in the manual it says that I need "silicone grease/ coax-19553-a" to lubricate seals, does this have another name? I went to the auto parts store and they looked at me like I was making it up.
  3. Krazy Comet
    Dismal Swamp
    The you could use the clearish silicone grease used on spark plug boots... I used chassis grease..
    The C0AX-19553-A grease is a ford part number that dates back to 1960... No doubt far better grease available today...
  4. Mlover
    Mlover Member
    Bay Area
    Ford Maverick 1974
    Can I use this chassis grease that I already have on on the seals?
  5. Krazy Comet
    Dismal Swamp
    I have the same grease in my gun...
    For seals & O rings(areas in fluid path) you only need a very small amount, many will use P/S, transmission fluid etc... For sleeve, ball stud, etc you can be far more liberal with application of grease... Fluid does not enter into this area(at least not supposed to)...
  6. Mlover
    Mlover Member
    Bay Area
    Ford Maverick 1974
    My auto parts store doesn't carry hoses so I have to order online. Do you know any specifics of the hoses? I see a bunch online but not sure what specifically I'm searching for or how many of each type of hose?
  7. Mlover
    Mlover Member
    Bay Area
    Ford Maverick 1974
    Thanks again. I just finished my complete disassemble hoping this goes swell.
  8. Mlover
    Mlover Member
    Bay Area
    Ford Maverick 1974
    Unfortunately, I ran into a same issue. The kit I bought includes four of those small thick black rings. I know for sure two of them fit around the spool area with a hard plastic washer inside of them. However, where do the other two belong?
      File size:
      22.1 KB
  9. Mlover
    Mlover Member
    Bay Area
    Ford Maverick 1974
    Let me add that I referred to the manual diagram and another I found online. The youtube videos I watched also didn't show them installing these pieces either.
  10. Krazy Comet
    Dismal Swamp
    Use the pair that best fit the ends of spool valve, apparently some of the late units use a different size...
  11. Mlover
    Mlover Member
    Bay Area
    Ford Maverick 1974
    I have just about finished my project but seem to have run into one last problem. I managed to rebuild the control valve/get the new lines. I am in the process of installing it and I have threaded it on to same spot where I marked it, however now I can't seem to hook on the two small hoses nor can I move the new ball stud into the pitman arm hole. I'm doing this car on jacks, do I need to lift the car higher into the air to reinstall?
  12. Krazy Comet
    Dismal Swamp
    I inst complete system tie rod to tie rod on both my Comet and Fairlane... The distance between cylinder and valve should be same as prior... The uppermost hose on cylinder connects to upper port on valve... If you cross them the steering will cycle wildly back & forth...
    What's not centered with ball stud? Just angle or is it too far to one side?
  13. Mlover
    Mlover Member
    Bay Area
    Ford Maverick 1974
    I made a small paint mark on each line to ensure I made no mistakes rehooking them, and the new hoses compared to the old ones seem identical. I think the problem is just that I need to hook the ball stud to the pitman arm first.
    It seems to be to far to one side. In the only video reference I found, he sort of adjusts it up into the port (but his car is fully suspended overhead) but mine doesnt seem to move that far or to be able to reach the ball stud.
  14. Mlover
    Mlover Member
    Bay Area
    Ford Maverick 1974
    Not sure if these pictures will do any help (only ones I snapped) the pictures show it way closer than it actually is. But the pitman hole is closer to the center of the car and the ball stud is closer to the wheel.
  15. Krazy Comet
    Dismal Swamp
    Just move steering wheel till arm lines up, really can't be off center if fit's back together...
