converter stall speed?
Discussion in 'Technical' started by benben, Jan 31, 2007.
  1. ShadowMaster
    ShadowMaster The Bad Guy
    The ShadowLands
    1969 1/2 Maverick
    Any performance modifications at all should require an external cooler. In fact, if you get one of the good B & M race coolers (or similar design) you could run your lines directlyl through the transmission cooler and bypass the radiator section completely.
    No way in hell.
  2. PaulS
    For any high output engine and even a stock one that is run hard a cooler is necessary for long life. A high stall converter just adds to the heat load of the transmission and with a higher stall converter you need a larger cooler.
  3. Tylar Miles
    Tylar Miles Try try try let it ride..
    Lawrenceville, ga
    1993 Nissan Sentra
    The red 72' stalls out at 1600rpm. It has the stock torque converter from our 73' 4 door with a 250.
  4. stmanser
    Davenport, Iowa
    my convertor is 2500 and it works well for me.. i have a mildly built 302
  5. benben
    benben Member
    Europe, Estonia, Tallinn
    Mav`75, 302, 2d, A/T, A/C
    Hughes, Transking, Art Carr, Ultimate Converter are but a few of the better units. Don't buy a damn thing from Ebay. Call one of these companies and get ready to talk.[/quote]
    To: ShadowMaster Can you give addresses of these companies, www.....? Try to find from google, give me lots of pictures of Hugges family, beautiful.
  6. ShadowMaster
    The ShadowLands
    1969 1/2 Maverick
  7. scooper77515
    Good question, and good responses, considering that there are 3-5 people struggling with this question right now...
  8. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    so do we get a discount:p
  9. scooper77515
    No, they will probably tell you to F$@k off!!!:D
    OR maybe charge you a bit more to cover all the discounts they gave him...
    Isn't Performance the guy in Houston where you got your mav? With the dyno?
  10. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Most of these companies give free tech advise, then get your part # an shop around.
    Performance Automatic prices are cheaper at parkwayford performance.
  11. scooper77515
    OOOPS! Wrong Performance...:huh:
    That is usually what I do... Call Shadow, ask what is the best part for my project, the call around for the cheapest place to buy it
  12. ShadowMaster
    The ShadowLands
    1969 1/2 Maverick
    True. Joe Charles will cut you some slack over prices. Just tell him I said his Mach I is a turd and see where that conversation ends up. :rofl2:
  13. benben
    benben Member
    Ok, Im ordering converter from PA.
    To: Shadow Master, Harvey Baker say "Hi" to you :)
