Cost of Rust, Body, and Paint?
Discussion in 'Cosmetic' started by Deerhog, Mar 4, 2017.
  1. 73curtis
    73curtis Member
    ohio
    P
    Looking good!
  2. fullcm
    fullcm Doug
    Michigan
    74 maverick
    thanks, maybe we'll cross paths at a meet someday.
  3. 73curtis
    73curtis Member
    ohio
    yes, was at the Geneva Ohio comet , maverick , pinto bobcat meet this afternoon lots of great cars and always nice people. Have fun putting the rest of your car together.
  4. fullcm
    fullcm Doug
    Michigan
    74 maverick
    Didn't know there was a club for Bobcat owners. I had a really clean '78 when I was in the Navy, of course that was in '83 so I guess it was only 5 years old. Great little car though.
  5. airford1
    airford1 Member
    San Dimas, Ca
    Who has served the longest Paint Jail?
  6. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    You are a ' blessed ' man ! Most of these cars have problems in the cowl areas. You may want to vacuum the debris out of the ' inner ' areas of the cowl and then spray a liberal coating of OSPHO ..( You can find it @ Ace Hardware, Lowes, Home Depot . etc. etc. ) and it's not expensive . Spray it FULL STRENGTH .. Don't dilute it . It will stop the
    rusting and provide protection for quite awhile . Another approach is to remove both fenders .. and inspect the Drain
    Areas to see if they're clogged with debris .. if so .. Vacuum .. and apply more OSPHO ...It's not that difficult to get the fenders off .. and you"ll be able to see the drains when removed and also use a 'long - skinny ' probe to remove any loose debris and trash which may be sitting on the shelf . We've done extensive repairs on Cowl Areas on many cars and it's worth the effort if you're planning on working the car up . Just my two cents pal.
    Cometized
    (Chip)
  7. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    It's probably NOT your rubber windshield gasket . Try pouring it INTO the cowl area ONLY .. Sometimes the inner
    cowl has almost imperceptible small holes which allows water to enter more slowly than if the holes were larger.\
    Cometized
    ( Chip )
