Cougar Taillight Conversion
Discussion in 'New Members Forum' started by abesshop09, Jul 2, 2019.
  1. 71gold
    I did mine with brake light sequencing.
    farmerjimbob and BBMS18 like this.
  2. abesshop09
    abesshop09 Member
    Oceanside, Ca.
    1970 Maverick, 1998 Explorer Sport
    Ok I found what you are talking about, now I have another question about the relays why do you need them if the sequential turn signal modules are jus plug and play?
    These modules feature sophisticated electronics that automatically adjust the sequencing speed to match the turn signal flasher in your car. While other products offer you fixed timing or complicated manual adjustments, our modules sense your car's flasher speed and adjust the 1-2-3 sequence timing for you. Want more separation between individual lamps? Just put in a slower flasher!
    If your car has combination stop/turn signal lamps, these modules will sequence the turn and emergency flashers only. The brake lights operate normally!
  3. yellow75
    Tillamook Oregon
    The reason for the relays is because of the use of larger wire going to the rear of the car. If you want just hook them up like the directions tell you they should work.
    I also hooked mine up for brake light sequencing
  4. abesshop09
    abesshop09 Member
    Oceanside, Ca.
    Oh ok, I guess it couldn't hurt to get the relays just in case I decide to use them at a later time and since they are on special right now
    Thanks for all the helpful information
  5. 71gold
    no relays on mine...:bouncy:
  6. abesshop09
    abesshop09 Member
    Oceanside, Ca.
    and it looked good in the video :thumbs2:
    71gold likes this.
  7. bmcdaniel
    I have '68 Shelby lights in mine. Just use LED bulbs and you don't need larger wires and relays, the LEDs only draw 1/3 the current of incandescent bulbs. The LEDs are brighter and turn on and off faster, too. The Web Electric Products sequencers are what I'm using, also.
  8. abesshop09
    abesshop09 Member
    Oceanside, Ca.
    Which LEDs are you using are they the tower type?
  9. bmcdaniel
    Yeah, the tower type. 60-some LEDs on each. Sumbitches are bright!
  10. abesshop09
    abesshop09 Member
    Oceanside, Ca.
    thanks
  11. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Except that LED tail lights look terrible in classic cars.
    :hide:
  12. 71gold
    and when did Mavericks become ...classic cars...:huh:
  13. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    When they turned 25 years old.
  14. 71gold
    that just made them...old cars...
    "A classic car is an older automobile; the exact definition varies around the world. The common theme is of an older car with enough historical interest to be collectable and worth preserving or restoring rather than scrapping."
    with that being said, how many got crushed for scrap metal...:huh:
    mojo likes this.
  15. mojo
    mojo "Everett"- Senior Citizen
    Some might say the same thing about all of the different aftermarket wheels on these cars! You don't know the LED lights are in the car until lights, turn signals or brake lights are activated. Wheels are on all the time. I replaced my tails w/ LED's for a matter of "what I consider safety enhancement " All a matter of opinion!
    Shorty likes this.
