Could it be this easy (gauge cluster)?
Discussion in 'Cosmetic' started by RASelkirk, Apr 20, 2008.
  1. scooper77515
    I will take one!!! You ready to mass-produce them yet?
    Looks really nice, and if one isn't fond of the gauges, should be a cinch to swap to whatever style you like.
  2. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    It's really pretty easy, just a piece of .080" alum about 6 x 11 bent and trimmed just right (however, it does require some mods to the defroster duct and some minor grinding on the wiper motor support). I may offer up a template... Any standard 5" gauges will work.
    Russ
  3. rayzorsharp
    Looks very cool Russ! (y)
  4. Rando76
    Rando76 Member
    Claremore, OK
  5. A_Bartle
    A_Bartle Stallion Dreamer
    Michigan's Thumb
    1976 Yellow 2-door Maverick
    Russ,
    Looks awesome! How did you do the lettering around the indicator lights? Looks very professional...
  6. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Having a printer/cutter makes it a bunch easier. Actually, I made two aborted attempts at hand painting the bezel rings before I thought to cut some 0.100" wide "pinstripes" from my roll of silver metallic. I then went on to design and cut the lettering (which is a b!tch because it's so small) and that took four attempts to get it cut and weeded.
    <TIP> Anyone can pick up a small roll of pinstriping tape and "re-ring" your cluster face!
    Russ
  7. Mavaholic
    Very slick looking!!!
  8. Wilbur Green
    Wilbur Green Member
    Plymouth, Ohio
    76Stallion, 762dr.
    Very nice, looks awsome.
  9. jbbossmav
    jbbossmav Member
    md.
    71 maverick grabber
    im going to try and put autometer guages in my dash. i bought autometer phantom tach and speedo in 3-3/8 dia and i got a maverick cluster on ebay for .99 cents.
    they fit in the cluster very well. the cluster under the cover is flat. i need to make some kind of backing plate to retain them. wont be to hard.
    then i'l make some kind of plate to mount others under the dash.
    im using all white phantom guages. looks pretty cool
  10. john T
    john T Member
    coalinga CA
    72 maverick grabber
    so how is the wiring on that going. im looking to do that exact same thing now. i did see those guages and didnt like them by themselves but once they where in the cluster it was pretty cool. unfortunately i dont have the means to perform this mod so id have to have it doen for me :(
  11. john T
    john T Member
    coalinga CA
    72 maverick grabber
    holy crap dude......600 bucks on guages?!?!?!?!
  12. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Right, $600 bucks on 6 gauges (4 in one housing, 2 in the other) plus all the sending units. Life ain't cheap! ;)
    Russ
  13. 72MAVGRABHER
    Roanoke, Va.
    stuart warner routinely goes for 500+ bucks for their guage kits and dakota digital if you buy all you need...
  14. john T
    john T Member
    coalinga CA
    72 maverick grabber
    its weird i found that its about 20 bucks cheaper to buy them individualy
  15. 72MAVGRABHER
    Roanoke, Va.
    it normally is... look at edlebrocks top end kit for engines through summit, then price them individually. it's an astounding difference.
