couple of strange things....
Discussion in 'General Maverick/Comet' started by 71gold, Mar 29, 2019.
  1. Krazy Comet
    Dismal Swamp
    Maybe different in GA, but I heard Tits or Tires.
  2. 71gold
    found a situation...
    the EFI get's switched on power from... factory e-choke wire. now this wire still has power when key is switched off. been hooked up this way from start and has worked fine until now. any ideas why this would start happening?
  3. yellow75
    Tillamook Oregon
    Do you still have the actual switch down low on the steering column that the key operates ? What color is the wire you have the EFI hooked up to ? I was looking at the wiring diagrams that Jeff has provided and it does not show choke wire on a 73 but does for a 74 and I have pretty much traced it back to the ignition switch so it makes me wonder is the switch is out of adjustment a tad. Or somehow it is getting back fed from elsewhere ?
    http://1bad6t.com/Maverick/repair/chassis_electrical_05.html
  4. 71gold
    I thought of the adjustment thing so I checked . it goes to...on...start...back to on...then to off...acc.
    its a blk. wire that comes out of the plug with the two vac. lines in the firewall. it may not be E-choke wire but it was a switched on 12v.
  5. stumanchu
    stumanchu Stuart
    Portland, OR
    Just for grins, that wire that is hot still when switched off..... after it is switched off, go and turn off your kill switch and turn it back on. then check the wire again.
  6. 71gold
    it's hot with switch on... switch off it's off...crank the car, turn the car off..it's hot.
    kill the kill switch it's off... turn the kill switch on it's off...:bouncy:
  7. stumanchu
    stumanchu Stuart
    Portland, OR
    Do you have anything powered by the I terminal on the starter solenoid, or is that part decommissioned on your car? It would be powered in the start position, and possibly never turns off? (until the power is cut by the kill switch) I dont know the inner workings of that part to know if it is possible to malfunction in that manner. Or is there a different relay that gets power in the start position that never cuts out when the key goes to run?
  8. 71gold
    this comes from a...switched on hot from the fuse panel.
    I'm going to try and trace that wire back today and see what's up wid it.
    thanks for your suggestions
  9. 71gold
    this situation is ...peaking my interest more than frustrating me.
    now that I know what's happening and can solve it, I just want to know why it changed...:scratchchin:
  10. Hotrock
    Munroe Falls, Ohio
    Piquing not peaking. Sorry Frank, just had to do it.
  11. 71gold
    "feel irritated or resentful.
    "she was piqued by his curtness"
    synonyms: irritate, annoy, bother, vex, provoke, displease, upset, offend, affront, anger, exasperate, infuriate, gall, irk, get someone's back up, disgruntle, nettle, needle, ruffle, get on someone's nerves, ruffle someone's feathers, make someone's hackles rise, rub up the wrong way"
    not what I meant at all... just "takes my interest to the highest level ".
  12. Hotrock
    Munroe Falls, Ohio
    Definition of pique
    transitive verb
    1a : to excite or arouse especially by a provocation, challenge, or rebuff sly remarks to pique their curiosity
    Russell likes this.
  13. Hotrock
    Munroe Falls, Ohio
    I apologize Frank, I should not be critiquing anyone's writing on this website. It doesn't promote great community.
    71gold likes this.
  14. stumanchu
    stumanchu Stuart
    Portland, OR
    Well, I find your situation interesting Frank....but if it was my situation I think it would border on irritation! Lol...I am out of ideas except if a device downstream from your switch contains relays and is no longer grounded, it will continue to seek ground through other means? Good luck finding the problem, I hope it has a simple solution.
  15. 71gold
    OK...I went out and created another switched on source.
    it did the same thing...:yup:
    getting ready to make a call to MSD.
    ...to be continued...
    Earl Branham likes this.
