couple of strange things....
Discussion in 'General Maverick/Comet' started by 71gold, Mar 29, 2019.
  1. 71gold
    well today...found out I have no E-flashers or brake lights...:slap:
    will check fuse tomorrow.
  2. yellow75
    Tillamook Oregon
    Well it looks like things are cascading , maybe when you find thee problem for the no brake lights or flashers you will cure the other problem----one can always hope
    71gold likes this.
  3. 71gold
    things like this normally pop up a week before a meet, not months...:yup:
    as I've said before...it's my hobby car...so I like piddling with it....:bouncy:
    of course, when I am done with this I may need a ...:grouphug:
  4. 71gold
    3rd. ignition switch...same thing. pretty much think it's not the switch.
  5. mojo
    mojo "Everett"- Senior Citizen
    Three switches, guess you have to rule switch out -- unlikely 3 defective.
    71gold likes this.
  6. 71gold
    when first started yesterday it ran for a few seconds and died. I turned the switch to off and checked the wire, it was dead.
    today I think I will crank it, turn the key off and pull the fuel pump fuse, then check it for power...:huh:
    note...I was just looking over the install instructions and it said...no relay required.
    it has a built in fuel pump relay in the EFI, so in reality ...with the relay I installed it has two.
    ...:yup:...
    I may bypass the one I installed.
  7. 71gold
    going way out there...
    being this just started with the fuel reg. install...:scratchchin:
    maybe if I hook it back up to returnless it may make a difference...:huh:
    all I have to do is remove the return line connection and plug that port.
  8. 71gold
    OK...went out and removed the extra fuel pump relay.
    now it's hook straight to the EFI per instructions.
    NOW THE BIGGY...
    cranked it up, switched it off...still running.
    here is where it really gets weird...
    went to the back (switch off) and disconnected the feed wire to the fuel pump...
    at a minute it was still running. I tested the wire coming from the EFI and it had power. checked the one coming from pump...no power...:huh:
    before, if I pulled the pump fuse (at the pump) it would die in a matter of seconds.
    instead of being stressed out, I'm now more... weirded... out...:yup:
  9. stumanchu
    stumanchu Stuart
    Portland, OR
    Make sure your ground from the battery to engine and body are all tight and clean. Power is taking so many weird pathways in your car, you got to make sure the correct one is available. I would be checking every ground wire I could find at this point.
  10. 71gold
    and then...
    I took the fuel regulator loose and now no start...19 lbs. of fuel pressure...:slap:
    fuel gauge shows 52 percent fuel.
  11. 71gold
    just for S&Gs I picked up a couple gals. of gas.
    put it in...60 PSI on gauge...:bananaman:
    now the kicker...it cranks and shuts off with the key...:clap:
  12. yellow75
    Tillamook Oregon
    I guess you have a low fuel indicator now . How about the brake and e flasher lights I suppose they work now ?
  13. 71gold
    I'll check that tomorrow...:thumbs2:
    I guess it won't shut off until I go and get gas...:biglaugh:
    thanks to all that helped...:Handshake:
  14. 71gold
    going to hook the regulator back up tomorrow and see what happens....:yikes:
  15. CaptainComet
    I lost all track of any of this a full page ago ... :90:
    Sorry you are going through this.
    Krazy Comet likes this.
