Cowl Lacing Question
Discussion in 'General Maverick/Comet' started by BKelley, Jul 12, 2016.
  1. Grabber-1
    Grabber-1 Member
    long island ny
    71 maverick
    I'm guessing like these bit I could be wrong[​IMG]
  2. 55crownvic
    55crownvic Member
    colorado springs
    I tried the tape thing, but couldnt get it to stay stuck on the rubber, tried plastic and emblem adhesive, and even goop, but the tape still pulled off the rubber, so am gonna do the x-mass tree thing or I do have some plastic rivets that I think might work too.
  3. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    How could they mess it up ? I think these were originally made for a Mustang .. and they just figured...
    " close enough" and moved them out ! The Quality Control of Auto Parts has gone down the toilet in the past
    years and there's not a lot we can do about it but ' Weed Out The Weiners ' ..I've purchased various parts from
    a lot of different outfits and there are some .... that I would NEVER call again .. and others that are great!
    Cometized
    (Chip)
  4. 55crownvic
    55crownvic Member
    colorado springs
    Just did the rivet thing and worked perfect. I expect the x-mass tree pushin clip will work just as good. But I had the rivets and the tool so here it is........
  5. mojo
    I a rivet gun like/similar to that, never knew plastic rivets were available. Where you get rivets?
  6. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    The anchor looks ' clean ' and uniform. I have to ask .. why didn't you continue the strip all the way to the Fenders
    on each side. Just curious . I guess you could always add more later.
    Cometized
    (Chip)
  7. 55crownvic
    55crownvic Member
    colorado springs
  8. HadaGrabberonce
    HadaGrabberonce Member
    Talcott WV
    1973 Maverick 302 C4 3.55 Tractionlok Granada disc brake conversion Small front bumper
    These are similar to what I used. Some are hard plastic and some are soft. The soft ones are easier to insert. A little silicone helps too.
  9. HadaGrabberonce
    Talcott WV
    That looks nice. The small holes where you removed the original clips indicate just how far off they were. I gave Pony Parts Plus a neutral rating on Ebay for the Dennis Carpenter seal but I realize the problem is with the vendor.
  10. HadaGrabberonce
    Talcott WV
    Update: Pony Parts Plus contacted the manufacturer and they claim that they checked their records back to 2005 and had zero complaints on this seal. I replied that they should check out this forum on the numerous problems with this part. Hard to believe that in 11 years no one has complained.
    mojo likes this.
  11. HadaGrabberonce
    Talcott WV
    7/25/16. The manufacturer has now acknowledged a problem with clip location and is sending me a new seal. Thanks to Lynn from Pony Parts Plus for pursuing this matter.
    BKelley, Paul Masson and Craig Selvey like this.
  12. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
    Seems people found it easier to remove the clips and reinstall than to complain about clip placement. I spoke with Daniel Carpenter directly about this problem a few days ago and have also sent him a 70-72 cowl lacing for reproduction. I have no idea how long it will take to get the problem corrected on the current 73-77 lacing or when the 70-72 lacing will become available. I will keep you all informed.
    HadaGrabberonce likes this.
