Cowl rebuild
Discussion in 'Cosmetic' started by AquaInferno, Dec 31, 2015.
  1. AquaInferno
    AquaInferno Member
    Orlando
    1974 Maverick
    Hi everyone! I finally got the cowl removed and need to remove rust and rebuild. Does anyone out there have any suggestions on interchangeable parts or know where I can purchase a cowl from a donor Maverick? My car is a 74.
  2. mav1970
    I used reproduction sections for a Mustang for the rings and also some of the curved pieces that came with those sections - the entire section is not a direct fit but some of the areas of the new steel worked out great
  3. AquaInferno
    AquaInferno Member
    Orlando
    1974 Maverick
    What year mustang reproduction?
  4. mav1970
    Sorry, I didn't make that note in my list of purchased parts - you might be able to match up something going on the web site for CJ Pony Parts
  5. AquaInferno
    AquaInferno Member
    Orlando
    1974 Maverick
    I ordered thsee a few minutes ago from npd. 1965 mustang reproductions. I pray they are close 136-1lh.jpg
  6. mav1970
    2475 Welding in left side Mustang ring.jpg 2487 Right side Mustang cowl replacement.jpg 2491 Fitting and welding in right side Mustang ring.jpg OK, I found some photos of my cowl repairs - I believe they are the same exact pieces that I used, but like I said, I used pieces of the replacement panel to do my repairs - here are some photos
  7. 71gold
    is your '74 an A/C car?
  8. AquaInferno
    AquaInferno Member
    Orlando
    1974 Maverick
    No its not.
  9. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    If you have the ability to get in there, you no doubt have the ability to make those work! I am so thankful I don't have that issue.
  10. AquaInferno
    AquaInferno Member
    Orlando
    1974 Maverick
    Yeah that was my biggest problem. I have it torn down. I've taken it to a local old school auto restorer who's gonna fab. and weld the cowl. Ive taken out the windshield and taken down the headliner removed carpets and seats. I plan on replacing windshield gaskets, carpets and head liner. Does anyone have any suggestions of any other things I should do before putting it back together. I was contemplating taking the motor out now and doing some things to it. Any thoughts?
  11. Kevin Felsman
    Kevin Felsman Member
    Myrtle Beach, SC
    1974 Ford Maverick basic .250cid
    You might want to consider undercoating the inside floor pans while you have the carpet out. You can never have too much protection on that old metal.
  12. 71gold
  13. Paul Masson
    1971 Grabber
    I am too... NOW! And I also now have a great appreciation for anyone who has to fix this issue.
    That's usually how it ends up... http://mmb.maverick.to/threads/paul-massons-71-grabber.92251/
    I would also be sure to weld a temporary brace across the inside of the car just below the A-pillar area in case the car springs outward. i would also suggest installing the wiper motor and transmission onto the lower cowl panel so that you can line-up the wiper post holes in the cowl cover before you weld it back together.
  14. Kevin Felsman
    Myrtle Beach, SC
    I've been putting this task off for a while now, but it has to be done. I have the car prepped down to windshield removal. I don't know how or what tools I need to get the windshield out. I was able to get a good donor cowl (pictured), spot weld cutter, and a good drill. I don't have a place indoors to do this job , so any suggestions would be appreciated. Also I am deleting the air conditioning.] 20150706_174139.jpg 20150706_174251.jpg 20150706_174356.jpg 20150706_174408.jpg 12063791_10207797728720777_7630250864609578013_n.jpg 12141591_10207797728560773_8787811665894506593_n.jpg
  15. Paul Masson
    1971 Grabber
    Plan on buying a new rubber gasket for the windshield. Cut the front part of the rubber gasket off the windshield and it will pop right out. the only thing more common than rotten cowls on these cars is dried-out, cracked and leaking windshield gaskets, so get a new one for installation. You can duct tape the window back in overnight if you're worried about leaving it outside.
