Cowl Vent Cut Out
Discussion in 'Technical' started by mav1970, Sep 6, 2008.
  1. 302mav76
    302mav76 Isaac Serna
    Monterrey, Nuevo Leon, Mexico
    '76 Maverick
    I don't get why is it needed to cover it up with fiberglass if it can be welded shut.
  2. mav1970
    Once I finish sealing the vents off, I'll get some power to the blower motor and try it first before I make any attempt to get air in some other way. :Handshake
  3. 71gold
    BINGO!!! we have a winner...
    it takes the air it has already heated once and runs it back through and heats it again (recirulating)...in a few mins. you will have to turn the heat down so it doesn't get...too hot...:yup:
    the A/C does the same thing...all summer long i have never had my A/C on the...high...setting. i went to a cruise in yesterday...91 degrees...A/C on ...low setting...:thumbs2:
    ...the key...unhook the-vac. pod- that opens the...fresh air door...:tiphat:
    if i ever remove my heater box for some reason i am going to seal off the opening all together...i know i am getting some leakage around the seal on the door.
    ...chill'in in Ga....:cool:
  4. 71gold
    that's right...:thumbs2:
    they designed it so if you want...really cold air quick...
    "close off the outside air"... :huh:
    with my door in the...locked shut position...i have "Max" air on low and med...:thumbs2: just the fan is a lot quiter..
    ...:cool:...
  5. 71gold
    what are we "covering up with fiberglass"...
    ...:cool:...
  6. 71gold
    to do this you will need the car motor running and A/C on so the vacumn can...open/close... the doors in the heater box...:Handshake
    ...:cool:...
  7. mav1970
    I didn't mention that this is a non-AC car. I might be able to get a good feel for what it will do by just running 12v to it, to get the blower motor to move some air, and moving the doors open and closed by hand.
  8. 302mav76
    '76 Maverick
    hmmm...nevermind, I just woke up and didn't read it clearly. :)
  9. 71gold
    if you must...:huh:
  10. mav1970
    Oh---I must :rofl2:
    Thanks for the imput :thumbs2:
  11. 75 Vomet
    75 Vomet Member
    Shickshinny, PA
    75 Comet GT, 03 Ranger, '11 Fusion,'13 Escape S
    That 351 Cleveland Cobra Jet will be so quick, you wont need any vents.:drive::burnout:
  12. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Is that your finished panel? Looks like a store bought piece!
    Russ
  13. 71gold
    Yep!... thank you kind sir...:Handshake
    was my first shot at bodywork...
    ...Frank...:drive:
  14. soooulpower
    Mapleton Depot, Pennsylvania
    Dang! you wouldn't consider making another one to sell would you? :bouncy:
  15. 302mav76
    '76 Maverick
    I thought your wife did it, no offense :oops:. Well, at least I remember a picture of her applying the bondo or fiberglass on it. :)
