Coyote and a Maverick :)
Discussion in 'General Maverick/Comet' started by 69GT, Jun 18, 2010.
  1. maverick75
    In australia the coyote 5.0 comes with an eaton on top already. I Love the Falcon down there, its by far better looking than the new cars we get here.....
  2. cheezno6
    cheezno6 Member
    Central ILLINOID
    and the Rangers down there come in quad cab with turbo diesels :thumbs2:
  3. Maverick Man
    California
  4. 69GT
    69GT Member
    Fresno
    72 Grabber Maverick.
    You guys will love this :)
    Ford Motor Company 6.2 Liter V8 Engine - Big Change
    Sporting 379 CI, Ford's Newest Gas V-8 Packs Large Promise
    From the September, 2010 issue of 5.0 Mustang & Super Fords
    By Tom Wilson
    Photography by Courtesy of Ford Motor Company
    As the base engine in the...
    read full caption
    As the base engine in the 2011 F-250 and higher pickups, the 6.2 V-8 delivers 385 hp using a smoothly contoured but non-tuned exhaust manifold, and a long-runner intake. Manifold and tuning changes would easily deliver well over 400 hp with generous torque in more sporting applications.
    Ford's newest gasoline V-8, the 6.2-liter, is an interesting development. Architecturally it doesn't much resemble other Ford engines once above the head gasket. Its production debut is in trucks and yet it already has a performance background on the dragstrip. But most interestingly, the more you study the new 6.2, the more potential you see.
    Just to underscore that point-even though Ford certainly hasn't-the 6.2 is landing on dealer lots at 1.02 hp per cubic inch, in 5,500-rpm truck trim, no less. There's power lurking in this big engine.
    Obviously designed to deliver the one thing modular V-8s can't-cubic inches-the 6.2 has an indirect development history. Originally codenamed the Hurricane and rumored to be a cool Mustang mill, the engine dropped off the radar for a while before resurfacing as the Boss. But now it's officially just called the 6.2 and, so far, is purely a truck engine.
    What sets the 6.2 apart is its 115mm (4.53 inch) bore spacing. Modular V-8s such as the new Coyote 5.0 are limited to 100mm bore spacing by their production machinery. So to break the modular displacement barrier, Ford has gone to a fundamentally larger architecture. In the 6.2, that translates into a 4.02-inch bore.
    We've come to think of the 6.2-liter as a big-block modular. Of course, the only modular architecture making it through to the 6.2 is the bellhousing bolt pattern. We suppose the deep-skirted block, cross-bolted mains, and gerotor-style oil pump are modular thinking, but it's best to remember the 6.2 as its own engine family.
    What a Bore
    That large cylinder bore does wonderful things for the 6.2. Most basically, it allows larger displacements with less friction, weight, and length than the modular method of adding cylinders.
    Secondly, it allows large valves with reduced valve shrouding, so breathing is well supported. And while it may seem retrograde thinking to consider Two-Valve cylinder heads, the large bore allows good breathing with Two-Valve heads, which helps contain costs.
    Other than the larger bore, we don't see anything fundamentally innovative in the 6.2's short-block compared to other modern Ford engines. The block is cast-iron for durability, the deep skirts and cross-bolted mains are typical modern practice, and the gerotor oil pump is also typical. We also like the piston oil squirters.
    There is mention of improved bay-to-bay breathing in the 6.2. This is something Ford is big on, as it's mentioned by the company as a factor in the 3.5/3.7 V-6 family, the Coyote 5.0, and now the 6.2. In practice, it means the crankcase is ventilated, with windows through the main bearing bulkheads, so air pulses generated by piston movement can move more freely in the crankcase. Ford says there is good power from the technique; we guess it helps with ring seal.
    About the only gamble Ford took with the bottom end was simply the large displacement. No one knows where the economy or fuel prices are going (well, they're going up, but how much and when are open questions), so the cross purposes Ford is addressing with the 6.2 are delivering a large-enough gasoline V-8 in trucks, while not spending too much money in case the engine is driven into obscurity by $7-a-gallon gas.
    Shaft Rockers
    Where the 6.2 goes off on its own is in the valvetrain. Unlike any other Ford V-8 since you're granddad was buying muscle cars, the 6.2 uses a single overhead cam with splayed valves and shaft-mounted rocker arms. As we'll see, this is a cost-effective way of making good power, and it's definitely interesting in that it doesn't resemble any other Ford engine.
    What reasoning led to such a valvetrain? Well, the overhead-cam layout is flexible from a manufacturing standpoint because different cylinder head layouts can be easily bolted to the same short-block. Much as Two-, Three-, and Four-Valve cylinder heads have been used with essentially the same 4.6 modular block, Ford engineers were careful to design the 6.2 short-block so it could readily accept twin-cam heads. And that's sounding interesting to us: a big-block V-8 with DOHC, Four-Valve heads? Tasty.
    Overhead camming also frees up cylinder-head real estate because there's no need to accommodate push rods. That gives the cylinder-head designer more leeway in laying out the intake ports, exhaust ports, water jacketing, and head bolts. And sure enough, the 6.2 has large, symmetrical ports, the better to feed its large valves.
    A single camshaft per cylinder head is less expensive than dual cams, weighs less, and is more compact than a twin-cam head. The downsides are you have to work harder to package anything other than inline valves with a single overhead cam, and there are fewer variable-cam-timing options available because the intake and exhaust lobes are in a fixed relationship to each other on the single bumpstick.
    First considered for Mustang...
    read full caption
    First considered for Mustang use by Ford, so far the only 6.2 Mustang application has been Don Bowles 9-second drag car. Duplicating this one-off 7.0-liter with a production 6.2 is unrealistic, but sleeving a stock block might do the trick.
    With a large displacement, low-to-medium-rpm engine such as the 6.2, variable valve timing is certainly helpful, but not as critical as on a high-revver such as the Coyote 5.0. So single-cam variable timing certainly has its place. We'll note the 6.2 uses Cam Torque Actuation of the variable cam timing to reduce parasitic drive losses.
    Of course, inline valves are an inherent breathing limitation. Canting the valves outward is highly desirable, so Ford spans the distance from the centrally located cam to the splayed valve-stem tips using rocker arms. And to maintain rigidity, Ford opted for a stout shaft-mount rocker arm system. For a 5,500-rpm truck engine, the shaft-mounted 6.2 valvetrain should be absolutely bulletproof and stable. The medium rpm range of the 6.2 engine means the rocker arm mass isn't much of a bother, either.
    One reason shaft-mounted rockers haven't been popular with overhead cams is dealing with valve adjustment. Shaft-mounted rockers in overhead-valve engines can employ a traditional hydraulic lifter, but overhead-cam layouts have traditionally called for mechanical adjusters. Because taking your F-250 to the dealer for occasional valve adjustments won't do, Ford got crafty, installing a tiny hydraulic-lash adjuster in the valve end of the rocker arm. Visually hidden, the adjusters are fed via internal passages in the rocker arm and shaft. Meanwhile, the cam end of the rocker arm uses a roller tip to reduce friction.
    Thanks to its medium-speed rpm range and canted valve architecture, the 6.2 can employ some seriously large valves; right at 2.10-inch for the intake. These large valves obviously aid the 6.2's breathing, and considering both the canted intake and exhaust valves open into the combustion chamber, breathing should be excellent for a Two-Valve engine. That's borne out by the major-league power hot-rodded 6.2s have delivered when Ford took them racing.
    We were impressed by the Raptor...
    read full caption
    We were impressed by the Raptor R at the 2008 Baja 1000. Ramping an essentially stock 6.2 up to 500 hp, and getting it to live through this rough and dusty all-day plane crash, was a good trick.
    One casualty of those big valves is the practical impossibility of a centrally located sparkplug. Ford's solution was to fit two plugs per cylinder. Coil-on-plug ignition is used, with the coil sitting on the top plug and a traditional ignition wire firing the bottom plug.
    No doubt also to contain costs and in deference to the big-valves eating up the combustion chamber real estate, the 6.2 forgoes direct fuel injection for traditional port fuel injection. The injector does have a straight, vertical shot past the canted intake valve, however, so Ford is likely getting many benefits of direct fuel injection without the costly DI injectors and high-pressure fuel pump.
    The combustion chamber shape, described as "Hemi-like," is mirrored by a flat-top piston with minor valve reliefs for good flame front travel, along with what seems like a complex-shaped chamber in the head thanks to the canted valves. Energetic motion of the air/fuel mixture seems assured. Of course, Three- or Four-Valve heads could deliver completely different chamber shapes.
    A long-runner plastic intake manifold tuned for torque mates to the heads in typical modular engine fashion-via flat extensions of the intake ports jutting into the valley. The throttle body is electronic, of course, and is centrally located. So after decades of side-facing throttle bodies Ford has released two forward-facing throttle bodies for 2010 on the 6.2 and the Coyote 5.0.
    Aside from the shaft-mounted...
    read full caption
    Aside from the shaft-mounted rocker arms, the 6.2 looks like an over-sized modular V-8. The in-block water-pump housing, flat intake-manifold mating flanges, and timing chain layout are all familiar modular fare.
    Other details follow the latest Ford best practices. The crankshaft-position sensor is mounted at the rear of the crankshaft, and large separate cover plates are used to retain the crank seals. Numerous pips on the cam and crankshaft pulse wheels speak to high-accuracy engine management, and enhanced bay-to-bay crankcase breathing is cited. While the 6.2 was clearly designed for cost-effective horsepower, there is no overt cost cutting. Ford may have limited expenses with the 6.2, but it didn't do anything cheaply.
    Truck durability means the...
    read full caption
    Truck durability means the 6.2 features an iron-block with large coolant passages and dual knock sensors. Ford allows a 2mm overbore to the stock 102mm cylinder bores, giving 386 ci with the stock crankshaft.
    Built for Speed
    Curiously for a truck engine, the first 6.2s seen in public were in racing applications. The first was the mysterious drag-race engine spotted in Don Bowles' yellow S197 in NMRA competition. A Ford/Roush collaborative effort, the mystery engine (with apologies to Chevy's Mark III 427 Mystery Engine of early 60s Daytona fame) kept the Ford world buzzing with rumors in 2007, as neither Ford, Roush, nor Don would give a word of explanation about it.
    Don posted a 9.10/145 best with the unnamed, naturally aspirated engine in the 3,300-pound Mustang, which immediately tells you the combination was hitting in the 800hp range. What we now know is the beautifully detailed Bowles engine was a hand-built 6.2 prototype punched to an even 7 liters, or 427 ci. This was done by making a core change at the casting plant to get an extra 3 mm or so of bore diameter in the one-off iron-block, then over-boring the cylinders by the "organic" 2 mm allowed for field servicing. The resulting approximately 5mm-larger (0.194-inch) bore gave Don's engine about a 4.217-inch bore-call it a 4.250-inch bore among friends. If necessary, lengthening the stroke a bare 2 mm to 3.82 inch would have given the magic 427-inch displacement with a 4.217-inch bore.
    Likewise, Don's cylinder heads were developed finding their limits. First they ported a set of stock castings as necessary, then cut those heads apart to see where they were thin. Some form of rapid prototyping fabrication was then employed to make special heads with the necessary extra metal. These castings were ported further. The eight-throttle, individual-runner intake on Don's engine was obviously a one-off and allowed excellent top-end breathing for the max-effort drag sprints. Ford insiders say burning E85 fuel, this combination was tuned to between 750 and 800 hp.
    Dominated by its two large...
    read full caption
    Dominated by its two large valves, measuring 2.10x1.65-inch, the 6.2 combustion chamber is unique in modern Fords. It most reminds us of the Boss 429 "semi-hemi" or "twisted crescent" chamber of 40 years ago. The tall, straight intake runners are also prominent in this view.
    Closer to the real-world street is the 6.2 Ford ran in the 2008 Baja 1000. Bolted into the F-150 SVT Raptor R race truck-an amazingly showroom-stock Raptor with race-worthy suspension-this 6.2 was "production-based" featuring stock bore and stroke, but tuned to 500 hp. It completed the brutal off-road classic without a hitch. It is the basis of the "estimated 500hp" version of the 6.2 Ford has announced for the special FR F-150 Raptor SVT pre-runner. Only 50 of these trucks are to be built, and they won't be street legal.
    Finally, there was also a 7.5-liter, 850hp version Ford developed for a Trophy Truck application. No doubt the extra half-liter of displacement came from a long-stroke crankshaft; we haven't heard how successful that engine has been.
    Power Potential
    Ford initially abandoned the 6.2 for Mustang production for unspecified reasons, developing the more compact Coyote 5.0 as the main Mustang V-8 instead. The Blue Oval could build the 6.2, or some variation of it, for at least limited Mustang use. But with the impressive Coyote 5.0 liter now hitting the streets and the near-certainty of a supercharged version of the Coyote to come, it isn't immediately apparent where a 6.2-or a 7.0-liter-would fit in.
    Lack of a drop-dead obvious fit never stopped enthusiasm, however, and several good possibilities exist, including limited-run Cobra R or Super Cobra Jet specials using the FR Raptor engine. Or perhaps Ford has another limited-run Mustang up its sleeve. We just can't let go of what a highly placed Ford manager said to us: "You're going to see this thing hot-rodded in Mustangs." Was he hinting the factory has a plan, or simply that enterprising hot-rodders won't let this many cubic inches pass them by?
    Unlike the 5.0 Coyote, which...
    read full caption
    Unlike the 5.0 Coyote, which was designed to mate with tubular exhaust headers, the 6.2's exhaust ports are nearly square. Ford says the 6.2 was designed specifically to accept nearly any type of cylinder head with minimal work, so such details could easily change on future 6.2-or larger-engines.
    We don't know, but at the least the 6.2 seems a great Ford Racing crate engine candidate for crafty Mustang engine swappers. Hot-rodding started with durable, no-excuse, big-inch engines at moderate cost, and that's the 6.2 to a T. Sounds like a winning combination to us.
    6.2 Facts
    (as sold in 2011 F-250/350 trucks)
    Type 90-degree V-8
    Block Cast-iron
    Head Aluminum
    Bore 4.02-in (102mm)
    Stroke 3.74-in (95mm)
    Displacement 379 ci (6,208 cc)
    Horsepower 385 hp @ 5,500 rpm (411 hp in Raptor)
    Torque 405 lb ft @ 4,500 rpm (434 lb-ft in Raptor)
    Compression Ratio 9.8:1
    Sparkplugs Two per cylinder
    Valvetrain SOHC, two valves per cylinder
    Valve Size 2.10-in, (53.5mm) intake, 1.65-in (42mm) exhaust
    Camshaft 0.510-in (13mm) valve lift; 258/268 degrees duration
    Cam Timing Variable with Cam TorqueActuation
    Rocker Arms Roller, shaft-mounted
    Oil Capacity 7 quarts
    Fuel Grade 87-octane regular/E85 or any blend
    Knock Sensors Dual
    In Ford's Words
    Those at Ford intimately familiar with the 6.2 emphasized several characteristics of the all-new V-8:
    • Designed as a rugged workhorse specifically for truck applications.
    • Excellent port-flow characteristics, especially at higher lifts, which lends itself to lots of tuning potential, as evidenced in the drag racing experimental engine and the Baja 1000 Raptor R race truck.
    • With 115mm bore centers, the engine has lots of potential for increased displacement.
  5. maverick75
    Thanks for the article! I had been following the huracane engine years ago. But after it got discontinued the first time i thought they just gave up on it.
  6. 71gold
  7. 69GT
    69GT Member
    Fresno
    They already have all they need to make it a DOHC TVic GT40 or (PLEASE PLEASE!) Mustang motor. If it makes the same horse power per cubic inch the 5.0TVic makes (435) it will make 546 HP!
    Just imagine the junk yard finds and used motors for a low price in a few years!
  8. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Thanks Frank.
  9. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    Looks like there is plenty of room. I think I read that the Coyote is slightly smaller than the 4.6.
  10. maverick75
    How long though? :D I can never find LS motors around here. The JY guys pull them out before they even hit the yard. Even the truck ones never make it. But im just 21 anyways i can wait twenty years to get one in my mav :)
  11. 69GT
    69GT Member
    Fresno
    Oh. I was talking about the Ford 5.0 and 6.2 DOHC TVic motor possibilities for the future. The LS motors are plenty good for cheap power but I really don't see any advantage over a well built Windsor based motor unless you get to power levels where block durability becomes an issue. Or you save some weight by using an aluminum LS motor. In the end they are still both wedge headed push-rod motors :)
  12. maverick75
    I used them as a comparison to junkyard availability I wasnt talking about the actual engine. My point being that these engines will be hard to find because they will become just as desirable as the LS series.....
  13. 69GT
    69GT Member
    Fresno
    Oh, OK I was tired when I wrote that :)
    Yeah I get the feeling the junk yards are realizing the value of these mass produced bad ass V-8s showing up in their yards and are putting them on E-bay instead of having to let you or I walk out with a DOHC Cobra or LS3 motor for a few hundred dollars on "Half price day". :(
  14. mojo
    The "Reduced Price Day" at my local PP was eliminated last year. The cost is the same regardless of what day it is. They also started a $2.00 entry fee for all who pass thru the gates.
  15. 69GT
    69GT Member
    Fresno
    Yeah. They went to $2 to get in a long time ago here. And charge $5 just to get in on B.S. half price day.
