Coyote Swap Headers for 1971 comet
Discussion in 'Technical' started by Probot64, Dec 28, 2021.
  1. Probot64
    Probot64 Big Hat Racing. Ford powered Cars
    Corona Del Mar, CA
    1971 Comet GT, 64 Fairlane Pro Street, 1963 F100 Unibody, 1964 Fairlane 2 Dr Wagon
    I am well into my 2019 Coyote- 10 auto Speed swap into my 1971 Comet GT. Does anybody know if there is a set of aftermarket headers that w0uld fit into a 71 Comet/Maverick with an AJE K Member and their shock tower replacements? I have modified the factory 2019 exhaust manifolds to fit but want to go to a set of long tube headers. It looks like the BBK coyote swap headers for a fox-SN95 could work. I don't mind if I need to move a tube. Any suggestions would be appreciated
    Thanks
    Karl
  2. Mavman72
    Karl...Your in virgin territory with the Coyote swap. I would say that since the AJE setup is similar to an SN95 setup you may be on the right track with the BBK's but...Your the one blazing the trail here. There has been some talk/interest in Coyotes' in Mavs/Comets but no real input in that vein. On that note! I am sure the folks here would love to see your progress so far and will undoubtedly have something to say about it. Good luck man!!!
    Pete
  3. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    You get the double hiney hammer with the Coyote in a Maverick. It is not only the additional width of the Coyote but also the added height.
    Displacement Length Width Height
    302 Windsor 27.5" 18.75" 20.75"
    5.0L Coyote 26" 28" 27"
    TeeEl likes this.
  4. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    It's been done, just not sure it's been well documented.
  5. RMiller
    Kennewick, WA
  6. Probot64
    Corona Del Mar, CA
    Hotrock likes this.
  7. Probot64
    Corona Del Mar, CA
    I am thinking that a set of JBA or BBK 2019 Mustang automatic headers may be the best bet. Have taken some measurements and they just might fit. If I have to move a few tubes or slightly notch the frame rails/firewall/floor, I am fine with that. Will let you all know how it goes
    RMiller likes this.
  8. Meangreen71
    Meangreen71 Member
    AL
    '71 Mustang/ '72 Mach / '74 Maverick/ '77Comet
    Maybe one day they'll make an adapter to bolt a 10-speed behind Windsors.
    Good luck with build, and kudos for keeping it Ford-powered!
  9. Zack9832
    Zack9832 Member
    Clarksburg West Virginia
    73 Ford Maverick
    Im in the process of performing the same swap. Im using a C4 trans though. I have a set of BBK headers for a SN Coyote swap. I hope they fit. Im just wondering if Probot64 has any updates. I have my towers ready to weld in and my frame ready to mount the kmember.
  10. mojo
    You going to R&P steering? Coil-over suspension? I like those modified towers -- way Ford should have did it.
    Zack9832 likes this.
  11. Zack9832
    Zack9832 Member
    73 Ford Maverick
    Flaming River Manual R&P. The towers are from AJE as well.
    mojo likes this.
  12. Zack9832
    Zack9832 Member
    73 Ford Maverick
    A little update, the passenger side header is close to the frame rail but i think it can be clearenced to make enoguh room so it doesnt hit. For the driverside to fit I had to cut the front tube off the header. I am waiting for my steering shaft parts to come on and I will fabricate the new tube. It looks like if I route the front tube like the one on the passenger side I should be able to make it work.
  13. Zack9832
    Zack9832 Member
    73 Ford Maverick
    Passenger side for reference...
