crazy question
Discussion in 'Technical' started by all4glass, Dec 19, 2006.
  1. all4glass
    all4glass Member
    huntsville alabama
    1970 maverick 302
    i was told that if i had welded on the 50.s ounce weight ourselves that the fly wheel wouldnt be balanced properly therefore ruing the lower bearings .. now after 2 years it starts blowing all this smoke... im thinking i did some good damage lol altho seems to run ok now just blowing an awful amount of smoke thing is i have side pipes and qual smoke is coming out of both pipes
  2. cam1000
    cam1000 Member
    Eastern North Carolina
    check your pcv valve and make sure it is not sticking too. If the engine is building pressure in the crank case it will push oil round your rings and seals and cause smoke too.
  3. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    My car has a '70s look, and it doesn't have sidepipes...
  4. all4glass
    all4glass Member
    huntsville alabama
    1970 maverick 302
    ok did a compression check all cylinders come out at between 95 - 100 lbs now im really racking my brains...... could it still be rings or perhaps in the heads?
  5. mattmanb
    mattmanb Member
    Richmond, VA
    1977 2dr 302
    my first mav was a 70 w 6cyls i got from my dad's admin in 76. i had to drop 2 clutches and 2 sets of rings iin it in the 5 years i had it. it's a no engine pull job, just drop the oil pan an take off the heads.
    the pistons will come right out of the top ( on the 6, i can't comment on the 289 or higher v-8). it took me both saturday and sunday the 2nd time to do it but i drove it to school on monday.
    i also had to have the valves redone at my local machine shop on the first rebuild. the shock mounts in the rear that i had to remanufacture are another story (chasing cows at 30 to 50 mph through the pasture is not what the mav was designed for.) good luck,
    matt
  6. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    i think your goin to need a piston return spring(y)
  7. 89gtsleeper
    89gtsleeper Member
    OKC
    89 Mustang GT
    This is a very similar sounding problem to what I had. Mine turned out to be a piece of my #8 cylinder missing. I could actually see the top of the ring, as it was the edge of the top face of the piston!!!
