Crites Headers Not Available
Discussion in 'Technical' started by MavMark, Aug 27, 2008.
  1. blugene
    How many sets does that make? Then you know the minimum order...? Lame excuse tho. And the material may be plain raw steel which isn't worth it in my opinion. I like the ones here: http://mmb.maverick.to/showthread.php?t=24841
  2. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    What does that have to do with these?
    Those are good headers, of course, but they are for totally different buyers/cars than the Crites.
    The shorties are for mild to moderate performance street cars, and keeping ground clearance on street exhaust.
    The Crites are for putting the largest possible 'off the shelf' headers on a fairly radical 302 based engine or for 351w swaps.
    The shorties don't even come close to covering a 351w swap.
    So again, how do they compare as an alternative?:hmmm:
  3. bradleygt
    bradleygt Member
    grand rapids michigan
    1970 maverick
    by my calculations if the average tube length of 36" that 5000 ft order will make about 18 sets of headers that can be sold pretty fast for a group buy
    brad:)
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Your calculations are a bit off. If 5000 ft of tubing will make 18 sets that is just under 278 ft per set.
    It is probably around 150 sets with a generous scrap allowance.(y)
  5. fastback86
    fastback86 Loose cars and fast women
    FL
    1974 Maverick 351W, 1985 5.0 Mustang coupe, 1996 F150, 2004 Subaru WRX Sti (Don't shoot me, it goes like hell!)
    If you guys get them to make a run I'll buy a set within 60 days
  6. blugene
    I read "small block" and I suppose I didn't know this was about a swap...
    The Crites are not on "the shelf" anymore, right? :p
    I also thought the shorties is good for a somewhat radical built motor...:hmmm:
    Maybe I just don't know what i'm talking about...
    :outtahere:
  7. newtoford
    newtoford Member
    New Castle Delaware
    so what fits W's thats still out there?
  8. ratio411
    ratio411 Member
    Pensacola
    Hooker 65-66 351w Stang headers work with mods to the engine bay. 1.75" tubes on these.
    Tubular makes a set of 1.5" tube swap headers, but that is REALLY small tubes for a 351, and forget a stroker!
    The extinct headers are now:
    Hedman swap headers, 1.5" tubes.
    Crites, 1.75" tubes.
    Untried possibility:
    JBA makes a set of 351w in 65-66 Stang shorties... They are very expensive though. I doubt anyone has experimented with these. Good chance they will fit.
    Then there are always stock Maverick 302 manifolds.
  9. newtoford
    newtoford Member
    New Castle Delaware
    ive heard some varying reports on the stock manifolds...
  10. ratio411
    ratio411 Member
    Pensacola
    Yeah, so have I.
    I think the difference has always been in the engine mounts. My opinion anyway. I notice that folks doing the swap and posted problems with manifolds, are also ones posting threads asking about engine mounts and how to make them work. Gut feeling is that the 2 issues are related.
  11. maverick5.0
    maverick5.0 Member
    Caribbean/Puerto rico
    1976 maverick,347 stroker,c-4,sm bumpers,frt air dam/73 maverick,5.0 grabbber hood,four on the floor,v8,rear spoiler,...
    nascar is using tri-y hedders on all their motors...so their has to be a power gain with that configuration... does some have a part number/picture for the doug thorley tri-y for mavericks????? BTW I have DT tri-y on my 63 fairlane SC 4speed and they are perfect !!!!
  12. paxtond
    paxtond Member
    Ontario
    1971, 1976 Comets
    Summit still lists the 88660 351W early stang swapper Hedmanns for @ $150.00.
    Old stock? or where you refering to a different model Hedmann?
  13. MavMark
    MavMark Mega Modifier
    Detroit Area, Michigan
    I would be interested in getting a set within 60 days if we get a GB going...
  14. ratio411
    ratio411 Member
    Pensacola
    Do they have a Tri-Y for a Maverick?
    I haven't heard about that one.
    I put a Mustang Tri-Y set on my Sprint... and they didn't fit.
    At the time I was looking for a very mild setup, and the Stang version has very small tubes for torque production.
    Anyway, the steering and the Z-bar both hit.
    Edit:
    One thing about NASCAR... what works on their cars is often not going to work on the street, or is not worth the money vs power gain.
    They are known to spend many thousands, even hundred thousands, to gain 1 or 2 rwhp out of a part. So what they do is either not geared for the RPM range of a street engine, or is an expensive mod that is not cost effective for a street engine.
    Just some thoughts.
  15. ratio411
    ratio411 Member
    Pensacola
    I don't recall the part number.
    However, I believe it was specifically listed as a Maverick part.
    If it just says 65-66 Mustang, it is probably close, but it is a gamble.
    The Tri-Ys should fit. I gambled with those, and lost.
