Custom dash . . .
Discussion in 'Cosmetic' started by mashori, Sep 23, 2010.
  1. Mavaholic
    A 57 or 58 Ford. Whats the rest of the car look like?
  2. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    it's not too bad, it has a hardtop roof that's convertible. it's in primer all over. bryant is putting in an engine and T5. They were just working on the rear end and drive shaft. it's gonna be nice when done.
  3. indyman13
    indyman13 Member
    Little Rock, Arkansas
    Neat fabbin------I love that kind of stuff.
  4. Mavaholic
    They are called retractable hardtops. Only made in 57, 58, & 59. I have a 57 Ranchero and 57 2 door wagon. My favorite cars. Sorry for the detour, now back to your regularly scheduled thread. :D
  5. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    saw a very similar dash insert as Don's custom insert. Looked great. But this guy had some other stuff, I asked his permission for pics so I hope it's ok to post . . .
    This is how I like my gauges to look. Bryant and I are thinking of putting similar inserts into the dash.
    Hard to see in this view but the metal work is impressive. We may have figured out a way to do it a little easier. we'll see
  6. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I took a new approach and so far I like how it turned out.
    You can't see it in this pic but I cut out the entire inner part of the dash and used some cardboard to get the right dimentions for an aluminum insert.
    I kept the cardboard template in case anyone wants it.
    In this pic you can see the insert installed, no bolts holding it in place. Going to probably use riv nuts to hold it in later. The dash behind it is how I cut out the entire center section.
    We used whatever we had laying around to figure out the layout.
    We made some outlines with a sharpy and then used a punch to mark the cuts. I had to buy a hole saw for the drill 3 1/4 size which was expensive.
    Looks nice doesn't it? The center ones are for the tach and speedo 3 3/8" and the other smaller gauge will be 2 1/16" for the other gauges.
  7. 70 maverick
    70 maverick Member
    Ajo, AZ
    1970 Ford Maverick, 76 Mav for parts
    looks great! do you think it will be done before the az meet?
  8. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    yea, should be
  9. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Only problem I see is that you might want to put a satin finish on the aluminum with a scotchbrite pad or something. The sun will glare off the shiny aluminum, probably at the worst possible time!
    I had a stainless bug shield on a truck one time. Most of the time it was fine, but at certain times of the day when going the right direction, it would blind you with the reflection!
  10. 70 maverick
    70 maverick Member
    Ajo, AZ
    Cool! I would like to see it on the car!!
  11. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I don't really like the look of aluminum as a dash, it's a personal thing. I prefer to paint or actually powder coat it, I think it will match the interior more and look nicer. What do you guys think?
  12. Dave B
    Don't you think that all the gauges might be pointing downward? You may have to countersink them...
  13. car-nut
    car-nut Glenn
    conn.
    Exactly what I was thinking, countersunk and on an angled up towards the driver.
  14. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    how do I countersink the holes? I didn't think about the angles, thanks for pointing that out. It should give it a more 3D look if I put some PVS angle pieces. What I don't like too much about this dash is that it's so flat. It could use a bend and a curve . . .
  15. Dave B
    That's going to be an issue with using aluminum, unless you know someone with a tig welder.
