Custom ram-air
Discussion in 'Technical' started by Racer_X, Feb 28, 2011.
  1. bri
    bri midnight special
    mission city b.c. canada
    71 comet GT. 414 cu, c-4, 9+, spool 3.25, 35 spline axles, back halved,12 point,,4 whl wilwood discs, 3 link,tubbed. 73 comet sdn 302, 76 comet 2dr 6 cyl, 84 z-28 468. 98 f-150 4x4 5.4, 98 fld 120, 500 detroit. 09 jeep grand cherokee.
    yes thats true ..they also run cowl air to keep the chunks of rubber and other debris from plugging up the ram air intake screens when there right up another cars caboose at 200+ mph. not to mention the very hot track surface temps. would defeat the whole idea of cold air intake. unlike buddies car that might see the other side of 130 mph. for less than 1% of its life. so in a street car.. ram air is not such a bad idea..and ram air pressure is pretty much a non factor when considering carb. induction formulas in speeds under 100 mph for a street car. just a friendly opinion.
  2. darren
    Agreed. Its cooler air thats a factor in a street car and not the RAM AIR effect.
  3. Blown74
    Blown74 Member
    Va
    74 302 blown- 68 Shelby Gt 500- 69 Cougar XR7 428 ram air
    here a nice "ram air"
    This one works pretty good for me..:)
      File size:
      395.3 KB
      55
  4. Streamliner
    Streamliner Member
    You have to be running at least over a 100 mph to see any benefit from ram air
  5. PaulS
    You can set up a ram scoop to start working at most any speed. Above 60 mph it is relatively easy to get a ram effect with the room you have on most detroit iron.
    Tuning with ram air is the hard part. It is a lot easier to use cold air induction and easier to tune as well.
