Cutting coils
Discussion in 'Technical' started by CACollo, Aug 26, 2002.
  1. jeremy
    jeremy I build t5's
    Corona, Ca
    microsoft photo editor comes with office programs, it has a nice resize option.
  2. mavman
    mavman Member
    Arkansas
    Yes, cutting the coils worked great! 0 complaints, well except for those stupid speedbumps at Taco Bell....lol. It handles better than my buddy's 5.0 mustang too. The only downside to the handling is that the backside tends to get a little squirrely when the turbo spools up coming out of a turn. If I had to do it over, I'd definetly do it the same way again. A friend installed v8 600lb springs in his Comet, but now the front end sits higher in front than in back---kind of looks like a 4wd.
  3. CometGT1974
    CometGT1974 Gearhead
    Western NC
    74 Comet GT
    just my 2 cents.....I took alot of weight out of the front via aluminum heads, fiberglass hood etc....the car set up very high in the front so I took the springs out set them in a bucket of water and cut a coil and a half off with a torch....brought the car down about 2" - 2.5"
  4. Old Guy
    Old Guy Member
    CometGT74
    I like it! The part about putting the coils in a bucket of water and using a torch is a new one on me but wish I had thought about it years ago when we used to take our cars to the local Mobil station which had a drive on lift. For 10.00 he would take a pack of Lucky Strikes and set it under the frame at each corner. Then the blue wrench came out and he heated each coil until the car sagged down to just touch the top of the Lucky's. In the early 60's I was financially embaressed so had to drive rather cheap autos, like 50 Studebakers, 50 Buick coupe and dozens of other strange looking vehicles. All got the lowering job, rode like hell but man was it cool, just like ducktail haircuts don't you know
  5. CACollo
    CACollo Member
    Abq. NM
    1969.5 Maverick
    Well, where can i get some aftermarket springs? I don't need top-of-the-line or anything, just something better than stock. I paid $70 for the new set of springs i have now...how much more will aftermarket cost? Model #'s?
  6. jmglove
    jmglove Member
    Jeannette, PA
    1970 Maverick 342 in. stroker and 4-link,tubbed
    Here's another suggestion. Try using coils from a Boss 302 Mustang. They are higher rate and the same size. Just cut them down.
  7. Maverick Man
    California
    get them here
    I got mine from TMC Traction Masters... im not at home right now so I can't get you the number. Call 411 or 323-555-1212 for directory assitance. They are located in Los Angeles, CA.
    They are 600 lbs coil rates
    Good Luck
  8. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Check out http://www.p-s-t.com/
    If you talk to one of their 'tech sales' guys, they'll ask about your set-up and what application you're going to be running (street, strip, street/strip, weight, weight distribution, etc).
    When I purchased their 'Super Polygraphite Suspension" from them, I also bought a set of drag springs for $200.00. If memory serves me correctly (and I'm an old man), they had MOROSO make the springs. Took about 4 weeks to come in.
    Good luck,
    Rick
  9. Tony L
    Tony L Member
    Georgia
    73 Maverick 302 -
    Maverick man
    What color is yor light blue maverick? Is it turquirse/blue or a baby blue? Can I get the paint company and color code?
    Tony
  10. Maverick Man
    California
    It is a stock blue from the factory. The invoice I recall said it was special paint for that LDO model. However I have seen other non-LDO's that same color who knows. Anyways.. I had the body shop match up the stock paint. I am not at home right now but i can get the code off the door if need be. Some call it baby bule and I call it that too but I think the correct one is light bule... the best way to match it up is with the color code. Also I do not think you can really get that exact paint anymore.. you can... but I am sure you know Acrylic Enamel is illegal to spry in most states or all states these days. Anyhow I am sure they can match it up with todays new water based paint. Also remember ford had 2 other light bules as well. e-mail me to remind me to get the color code off the car.
    Hope that helps some what
  11. Maverick Man
    California
    Okies at home now.. the code is 3B... The roof I painted Lexus IS300 Bule... It use to be a Blue Vinal top.
    Here some more eyecandy ;)
  12. Rick Book
    Rick Book Member
    Thailand
    VERY NICE!!!
    (is that a Maverick I see in the background?) :D
  13. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    Very Funny! :D I like they way you think, Rick! It sure does look like a Mav in the background, but there seems to be something abstructing the view....
  14. Maverick Man
    California
    who said anything about a maverick... someone should have been more clear with me... i thought someone wanted info about the color of her jeans and blouse.
