Damn Column Shift
Discussion in 'Technical' started by Mr Nick, Jan 6, 2015.
  1. Mr Nick
    Mr Nick One with many questions
    Grapevine, Texas
    1971 Four-Door Maverick, 1962 Cadillac Sedan deVille (soon)
    Ah, except it wasn't at the bottom originally. That marking is from when I changed the trans filter and tightened it down there. In that position, my Reverse was Park, Neutral was Reverse and so on. It slips down so should I pull it up a bit or give it some slack?
  2. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    I would loosen the adjuster, put both the column and trans in park and tighten the adjuster at a middle point where the linkage has some free play (so neither of the arms has pressure on the rods). While you have it loose, put the shifter in park with the key in the lock position and see if it will come out of park, that should tell you if there are issues inside the column.
  3. Mr Nick
    Grapevine, Texas
    Thank you Rick, will let you know how it goes
  4. rthomas771
    Always mark things before you take it apart. This includes driveshafts, brake drums, steering wheels, distributors, door hinges or any other thing that can fit more than one way. It will save you a lot of time by not having to do things more than once...less headaches in the long run too.
    Mel Moeller likes this.
  5. Mel Moeller
    Mel Moeller Maverick Moe
    Twin Falls Idaho
    1971 Ford Maverick, Two 1973 Mavericks, 1974 Mercury Comet
    That is a good rule Jeff. I am really bad about not doing that and it does cost more work for me.
