damper
Discussion in 'Technical' started by Blown74, Mar 11, 2007.
  1. Blown74
    Blown74 Member
    Va
    74 302 blown- 68 Shelby Gt 500- 69 Cougar XR7 428 ram air
    Checked the damper position today - still looking for that ignition problem. Damper SFI- is at 330* at tdc so 0* represents 30* advance. It will get a total of 40* . Is this possible? Is the damper not keyed to the crank? Why would someone install it this way on a blower motor?
    Still searching..........
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Small block Fords used different timing pointers over the years. 10, 11 and 2 o'clock. Perhaps you have a mismatched parts condition. Most aftermarket dampers are setup with multiple marks.
