Dart block question . . .
Discussion in 'Technical' started by mashori, Jun 11, 2010.
  1. 408w-maverick
    408w-maverick Member
    Oklahoma City
    1974 Maverick 2 door
  2. 74 GRABBER
    74 GRABBER Member
    Peoria AZ
    1974 grabber, 1995 mustang GT, 1967 mustang coupe, 1956 Caddilac sedan Deville
    IMO your goals are not realistic.
    IMO 9.99 car and daily driver are not the same car. Some have done it but they are very few and far between. And I doubt your really going to be able to do it in california. Get pulled over once they arer going to have a field day with you.
    Take a look in the timeslip data base, 500rwhp should get you really close to the motor you need for a low 10 sec pass. But remeber its ALOT more than just a motor thats going to get you there chassis, suspension, driveline, weight, are equally as important if not more important than horsepower. Aerodynamics come into play at them speeds as well. I would figure on around 140 trap speed in the quarter mile.
    Not to mention the safety equipment and licensing to be able to run them times.
    a old requirement i found in a quick google, and I'm sure they have added alot since then.
    SFI Quick Reference Chart
    Tentative as of 12/18/06
    This chart is for reference ONLY and is in no way intended to supercede or replace the rules, regulations or specifications mandated by NHRA, IHRA and/or SFI Specs. This chart may also be incomplete as these specifications are subject to change on a periodic basis.
    SFI SPECIFICATIONS
    Mandatory at ET (or quicker) Item SFI Spec
    13.99 Drive shaft loop (slicks)
    13.99 Helmet (Snell K98+)
    13.49 5-pt harness (convertible) 16.1
    13.49 Approved rollbar (convertible)
    13.49 (IHRA) Drive shaft loop (slicks)
    11.49 Drive shaft loop (street tires)
    11.49 Approved flywheel & clutch (manual transmission) 1.1, 1.2
    11.49 Approved protective jacket 3.2A/1
    11.49 Approved roll bar for all vehicles
    11.49 Approved 5-pt harness 16.1
    11.49 Approved flywheel shield (manual transmission) 6.1, 6.2
    11.49 (IHRA) Approved mounted fire extinguisher
    11.49 (IHRA) Approved flywheel shield (automatic transmission) 4.1
    10.99* Approved roll cage (convertible)
    10.99 Approved harmonic balancer 18.1
    10.99 Approved aftermarket axles
    10.99* Approved transmission shield (automatic transmission) 4.1
    10.99 (IHRA) Competition License* Class D
    9.99 Approved flexplate & shield (automatic transmission) 29.1, 30.1
    9.99 Approved roll cage & window net* 27.1
    9.99 Master cutoff switch
    9.99 Competition License Class 4, Cat. C
    9.99 Chassis Certification
    9.99 Approved jacket/pants/neck collar/gloves* 3.2A/5, 3.3, 3.3/1
    9.00 (IHRA) Roll cage & window net
    8.99 (IHRA) Competition License Class C
    8.49 On-board fire system
    8.49 to 7.50 Chassis certification 25.4/25.5 (3600#)
    7.99 (IHRA) Competition license Class B
    7.49 & quicker Chassis certification 25.1E (2800#)
    7.50 & slower Chassis certification 25.2 (3200#)
    7.49 Competition license Class 3, Cat. C
    IHRA Pro Stock Competition license Class A
    150mph + Parachute required
    200 mph + Head & Neck Restraint required
    * Also required for 135 MPH or faster
  3. JHodges
    JHodges thumper
    Dora Alabama
    Your original build will have plenty of power for a street strip car. You can build a 1000hp "street car" but it would be extremely unrealistic for a driver and probaly wouldn't last any time on the street plus race gas and other stuff. An afr headed 331 with a blower should run high 9's to low 10's pretty easy.
  4. 408w-maverick
    Oklahoma City
    Simplest way to put this is,you can build a 1000hp car and dd it,all it takes is money look at drag week those car have way more than 1000hp,if ya wanna go fast you have to give up some comfort for saftey.
  5. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I don't think this car will be going faster than 11sec anytime soon. The fun is setting a goal for yourself and working towards that goal. The evil mastermind (Bryant) and I will always come up with new things I'm sure.
  6. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    man that would be so awesome. I'm still so high off of hitting that nitrous button in my car in fontana for the first time 4 months ago. Can't imagine going that fast . . .
  7. maverickdragger
    maverickdragger GearHead
    Oneonta, AL
    1973 Maverick
    oh man its amazing. we just sold our mustang. 421 small block ford. procharger with 36 lbs boost and a 250 shot of spray. 725 at the wheels without the belt or spray. 8.80 1/4 street car. once you get comfortable racing youll wanna go faster and faster
  8. 408w-maverick
    Oklahoma City
    ^Why was that car so slow??
  9. maverick75
    36 pounds on a procharger????
    was in a F2?
    that's when they max out, but that's also on 1000+ WHP cars.
  10. 408w-maverick
    Oklahoma City
    ^Accually the F3-131/135/139 all can push 45lbs,unless i missed where he said it was a f2 then they max at 38lbs.
  11. maverick75
    he didn't mention which one, but since the F2 is the popular one(at least in my neck of the woods) I assummed he would use that one for that power level.
    i always though they maxed out at 36..... last year i spent some time with a guy that built a 427W/F2 66 stang, greatest ride of my life!
  12. 408w-maverick
    Oklahoma City
    Yea couple of local guys have the F3 1's a 1700hp streetcar and the other is something like 2000+ outlaw track car.
  13. maverick75
    I wish we had 10.5 outlaw events in socal :(
  14. maverickdragger
    Oneonta, AL
    1973 Maverick
    it was a F3. 90 model coupe with 26/10.50 slicks.
  15. 408w-maverick
    Oklahoma City
    ^So did you idel off the line?What suspension did it have?
