Dash insert
Discussion in 'General Maverick/Comet' started by Eddie Maverick, Nov 20, 2007.
  1. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    Is there an insert that will cover the hole left in the dash if one were to remove the parking brake handle? If so where can one be found or bought?
    Thanks
  2. NAFORD302
    NAFORD302 Member
    SILEX MO
    77 FACTORY V8 AC CAR
    I Think You Would Have To Use A Fuse Box Cover .
    See If Some One Else Can Help On This
  3. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    So maybe a fuse box cover from a 76+ car?
  4. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    How did the later sytle dash fuse box cover fit normally? Did it have tabs in the dash for the cover snapped into?
    I just wouldn't want to use screws on it at all.
    I just took a look at it, and maybe I can fab up a piece of plastic to just cover the hole where the rod passes thru the dash.
  5. Craig Selvey
    Why would you want to remove the parking brake handle for?
  6. Jamie Miles
    Alto, GA
    I've had a few
    It's going away on my car!! Hate that thing right there on the dash. Going to put it down on the trans tunnel like Mustangs.
  7. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    Going 4 wheel disk, and may use s10 front calipers for the job, if so im gonna install line lock to the rears so i won't need it.
    If i use the caddy rears then i may keep it.
    Just trying to sort out my options.
  8. newtoford
    newtoford Member
    New Castle Delaware
    you could look for a later style lower dash that doesnt have the parking brake mounted in it and just swap the whole thing in.
  9. Craig Selvey
    The thing is.....if you live in a state that has inspections.....or one that ever will....they will want to see a parking brake.
  10. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    No inspections in Ca.
  11. Rando76
    Rando76 Member
    Claremore, OK
    Could the line lock count? :rofl:
