Dash lights
Discussion in 'General Maverick/Comet' started by x72COMETx, Jul 23, 2014.
  1. x72COMETx
    x72COMETx Member
    Vallejo CA
    Im switching all of my interior over to led lights but i cant find which bulb the ash tray and heater control takes. I rember seeing someone posted a list of which bulb goes were and the number bulb it takes.
  2. ZaksComet
    ZaksComet Member
    Cleveland, Ohio
    1972 Mercury Comet
    I did the same thing awhile ago, i wrote about it and listed which bulbs i used and where i got them under interior tech articles, brighter dash lights started by another member. I also have a few pictures of before and after. Hope this helps
    http://mmb.maverick.to/showthread.php?t=60255
  3. x72COMETx
    x72COMETx Member
    Vallejo CA
    Cool thanks,
  4. rthomas771
  5. Lzoesch
    Lzoesch Levi Zoesch
    Spokane, WA
    What about doing led strips around the stuff you want back lit? More consistent I would imagine.
  6. x72COMETx
    x72COMETx Member
    Vallejo CA
    Yes i am running a strip of white leds under the dash to come on when the dome light does.
  7. x72COMETx
    x72COMETx Member
    Vallejo CA
    How difficult is it to switch out the heater control light?
  8. rthomas771
    It ain't hard once you remove the speedometer cluster. The light socket comes out with the bulb from the rear of the controller. I used two table knifes to pry the cover off. Make sure the cover comes off straight or it will break the pins off the cover.
  9. x72COMETx
    x72COMETx Member
    Vallejo CA
    Thank you, when i first got the car i pulled the cover off and broke 2 pins so i went to the local junkyard and grabbed a few black covers out of all the mavs he had. Im preppared :)
