Dash pad differences?
Discussion in 'Parts Interchange' started by mercgt73, Feb 22, 2014.
  1. Paul Masson
    1971 Grabber
    My 71 dash pad has a notch. My car was built in late September 1970.
  2. Angryeyes
    Angryeyes Member
    Canada
    Mercury comet, chrysler 300, Kawasaki ninja 600
    Its always possible my pad was replaced at some point, Ill check build date later for y'all
  3. mighty76
    mighty76 Member
    calgary,alberta canada
    76 maverick,58 ford f250, 79 f150 stepside 4x4
    just went and looked at my spare in the garage, it has the notch, so i went to my car, it has a notch, but for no reason, not for clearance or anything, i think it is there to make you wonder why it is there,:huh::biglaugh:
  4. krelboyne
    krelboyne Remember
    Salem, Oregon
    This is a good discussion, other forums have similar discussions. Not sure that we will come up with a definitive cutoff date. Different factories and different colors, will probably mean that there will be variations.
  5. Falcenac
    Falcenac Member
    Sechelt B.C. Canada
    1969.5 Maverick 71 Comet G.T. 76 Comet 4 door 61 Falcon x2 60 Frontenac
    If you mean like the windlace on the pinch weld yes
  6. Dave B
    No, there are plastic filler pieces, in between the dash and the a pillar.
  7. mav1970
    I believe my 70 has plastic filler pieces at the A pillars just at the dash :)
  8. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    My 72 Comet dash pad has those notches.....
  9. jtown77
    jtown77 Member
    Arizona
    71 Comet
    My dash pad has a date stamped on the bottom (23 6 71) and has the notch.
  10. mercgt73
    I was thinking about checking to see if there was a part number / date code stamped on the dash pads. I will have to re-check the green one now. (y)
  11. schroensr
    Berkeley Springs,WV 25411
    1975 Mercury Comet
    I will look at mine , I have the dash tore apart . Everything is out . Thanks for the heads up .
  12. mercgt73
    I double checked the green dash pad while I was at the shop this morning. There are no legible date codes on the underside. All I found were the handwritten numbers 171 and a circled 4. Probably part of the QC or assembly process, not made by a machine. :huh:
