dead Mav
Discussion in 'Technical' started by Retta Ranch, Jun 9, 2009.
  1. CaptainComet
    For fire ants ... get some Quaker Quick Grits ... (do NOT cook them :D) ... sprinkle them on the fire ant beds dry.
    The fire ants grab them as food and bring them back to the nest. They all pig out on grits and having no water to wash them down, the grits kill them. I believe that it is because once the dry grits hit any liquids internally, they start to swell up... pretty much blow them up from the inside out. :clap:
    If it rains on the dry grits, then you are just feeding them.
    Good luck with the timing chain ... when you said it went "Bang" and stopped running that was my first vote.
  2. qicvick
    qicvick Member
    ft.worth,tx
    1972 grabber
    5 qts. of used oil from your next oil change will remove the fireants, oil came from the ground so your just recycling :huh:, don't remember who you said did the work(can't look back while posting) but if u paid for it maybe they will help u, it does sound like timing chain or gear issue
  3. Retta Ranch
    Retta Ranch Member
    Grandview, Texas
    1973 Maverick 2-door, 1971 Maverick 2-door. 1962 Galaxy 500
    mr chilton and I did it, :D although my hubby happened to be through town, and checked it. I'll figure out what happened, and fix it. If it was something I did, then I won't do that again! So far, this whole Mav project has been mostly fun. I enjoy the puzzles, and figuring these things out. I realize it's 37 years old, and things are going to happen. Ideally, before my teenage daughter started driving it, I would have had the motor totally rebuilt, and everything else done. Unfortunately, we couldn't afford that route, so she's driving it as I work on it. She's due back from Amman, Jordan from a mission trip on Wednesday, so I guess I better get busy.
    Rhonda
  4. don graham
    Good luck. Hope it's a relatively easy fix.:)
  5. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    I am not familiar with 6 cylinders but if it's much like the v8's here is what might of happened. If there is a dowel locking the gear to the cam the dowel might have been left out, broken or too short to hold the cam gear.
    You will have to figure that out then re-time the cam with the crank inorder to get it running again. I would also check the oil pump drive very close as well
    When I lived in Texas a couple of years the old timers would take a shovel full of fire ants from each hill and mix them up. He said they would go to fighting each other and kill each hill out.
    clint
  6. 20cows
    20cows Member
    West Texas
    74 Maverick
    Half a cup of gas will take out the whole mound. The hole's not very deep and the vapors will get'em all.
    It works better if you can resist the temptation to light it.
    But it ain't as fun.
  7. Retta Ranch
    Retta Ranch Member
    Grandview, Texas
    ok, so now everything is undone to get timing cover off. A few weeks ago when the gears/chain were replaced, it came off rather easily. It didn't just fall off, or anything, but it did come free.
    This time, it won't budge. "Mr. Chilton" suggests to "gently pry the cover away from the block". He seems to be a master of understatement. Things like "remove radiator, fan and pulley, and engine drive belts." hmmph! Any ideas? Oh, and I did double/triple check that I removed all bolts, and the condenser is moved forward.
    Rhonda
  8. 71gold
    i use a...Dead Blow Hammer...:smash:
    ...:yup:...
  9. CaptainComet
    It is likely that brand-new gasket and the gasket goop are holding it on pretty good.
    How about using a small chunk of wood and a hammer? The wood should keep you from denting it too bad.
  10. TUK101
    TUK101 Member
    Elk WA
    72 Maverick 4dr/302 V8, 1963 Ford Custom 500 inline 6
    Double check that you have gotten all the bolts out. Use a flashlight and a mirror to see all around and in the nooks and crannys. Once you have done that, get a 2 or 3 inch putty knife and try prying it in between the mating surfaces between the cover and the block and use the knife to cut the gasket and sealer to get the cover off. Sometimes even a flat blade screwdriver will suffice to get that stuff started on separating. What I have found is that if you dont use something to get the gasket sealant cut on a large surface like that is that you risk springing/tweaking the metal that you are trying to get off from the block and sometimes that will make it tough to get it sealed again.
  11. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    Don't forget the 2 corner bolts holding the oil pan onto the timing cover! Easy to miss. Should be a 1/2" and a 7/16 on each corner.
    I think there is also a couple of 3/8" head bolts down low that are real easy to miss. That and like said just pry out easily as depending on how much gasket maker was used it might be stuck pretty well.
    clint
  12. Retta Ranch
    Retta Ranch Member
    Grandview, Texas
    another sad day :-( Here's what I found: broken camshaft, thrust plate, one gear has a tooth missing, chain broken, and timing chain cover broke. The cam broke off in front of the gear for the oil pump. The front bearing is toast. So, I'm off to price parts. My husband said we could go one step above stock on the cam kit. Oh, found out the motor mounts are all but gone, so I guess I'll add them to my list. That's the only thing on the list I've actually done before. Encouragement always appreciated!!
    Rhonda
  13. 1973Maverick357
    Cookeville TN
    Time for a 302 ;)!!
  14. 71gold
    the part you need is a...motor...:yup:
    there is more than...replacing a cam there...
    ...:cry:...
  15. Retta Ranch
    Retta Ranch Member
    Grandview, Texas
    ok. does anyone local have a 200? Have a feeling it might be easier!! I'll post to the classifieds here, too.
    Rhonda
