Delay Wipers
Discussion in 'Technical' started by Corbin Johnson, Dec 22, 2002.
  1. Thack
    Thack vision advicator
    Moreno Valley Ca
    The truck one looks just like that one. I removed the mounting bracket from the box becuase of lack of space. I also used the spacer from the maverick switch that has the right curve to match the dash and all its mounting hardware.
  2. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    Great, thanks Thomas. I guess I have a couple options on where to get one now. Where did you mount the box? Towards the side of the dash behind the heater controls? Thanks.
    -Corbin
  3. 71gold
    seems like we just talked about this same subject ...yesterday...how time flys...:thumbs2:
    ...Frank...
  4. Jamie Miles
    Alto, GA
    I've had a few
    Frank, were you able to get that switch to work?
  5. 71gold
    not yet...i went to the parts store and she pulled from 70-up...all were the same. there was 1 she didn't have in stock so she ordered it..(y)
    i will check it out and see what the diff. is.
    everyone said theirs were...plug-amd-play. :huh:
    ...Frank...
  6. Jamie Miles
    Alto, GA
    I've had a few
    Yea, mine was! Both in the '69.5 and '72, the switch just fit right in and everything worked great. Will be interesting to see what the difference is.
  7. mav6977
    mav6977 Member
    Wichita Falls TX
    various years
    I thought you could only get interval wipers in the 76/77 Mavericks by ordering the Convenience Group? Were they available seperate? My 76 Pinto wagon had the factory interval wipers. I still miss that car!!
  8. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    If you can't find them there
    Check out AMC...You know Pacers Gremlins Jeeps Especially waggoneers and Cherokees. They used the Ford delay control module and switch and just put an AMC sticker over the Ford script. The knob is also different but a ford knob fits right in the switch also they are good for many years from the 70's and 80's.
    this is what the unit looks like
    http://www.tomsbroncoparts.com/product.php?id=1262
    here is an article on the ford truck forum (granted it is in a truck but you get the gist of it)
    http://www.ford-trucks.com/article/...ll_interval_wipers_on_a_7379_Ford_pickup.html
    And one on the jeep forum (don't worry about the 3 wire or the 4 wire motor it does not affect us) that gives out some good info
    http://jeepsunlimited.com/forums/showthread.php?t=693983&highlight=intermittent+wipers
  9. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    If anyone needs or want one I have 5 complete units 3 unit that need switches .
    PM me
    jay
  10. BADBIRD63
    BADBIRD63 New Member
    Georgia
    Have a couple of Falcons, wich is close to a Maverick/Comet.
    Don't forget the 2 speed wiper motor, late model mid 80's to early 90's f series and bronco will work. You can get the delay box and wiring harness, the plug will be red if it is equipped with a delay box. Some of the switches if you push them in a small amount it will activate the windshield squirters, so you can even adapt them to work with your mav/comet. I tried testing my motor before I installed it and it wouldn't work. I found out the motor body was a ground along with the ground wire in the harness. So look out for that.
