Desert Mavericks.......Sand Box
Discussion in 'Other Automotive Tech & Talk' started by Ryan, Jun 1, 2011.
  1. 2mav4u
    Tolleson Az
    Who wants to help get a Grabber running? It has a 200ci
    Anytime before 1pm weekdays
    Gene Fiore and Static like this.
  2. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    If I wasn't working that would be fun.
  3. 2mav4u
    Tolleson Az
    How do I take out the ignition cylinder from steering colum? Bought the Grabber without keys. Engine cranks but doesn't start and I think its because the ignition isn't on the on position.
  4. 2mav4u
    Tolleson Az
  5. Craig Selvey
    Changing your key/ignition won't fix that problem. All the key does when it rotates is move a rod down the column to the ignition switch. That is probably your problem.
  6. Ryan
    Ryan Ford Addict
    Phoenix Az.
    If you dont have the key and cant turn on the ignition then it wont start unless you jump power to the coil. You cant change out the lock cylinder very easily witout the key. You will need to break out or drill out the tumbler then remove like you normally would which I forget how exactly on these .
  7. 2mav4u
    Tolleson Az
    Got the key made but still doesn't start. Doesn't even crank with key. Must have a short somewhere. Damn electrical problems
  8. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Who all is going to make it to the meet this Sunday?
  9. Static
    Static Member
    Apache Junction AZ
    1975 Maverick 2 Door
    I will be there
    Gene Fiore likes this.
  10. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    I have heard from Steve Huff and he will be there and I have another buddy who is planning to come.
    Static likes this.
  11. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    See everyone Sunday!
    Static likes this.
  12. 2mav4u
    Tolleson Az
    See you guys there.
  13. 2mav4u
    Tolleson Az
    Good turn out.
    tbirdz12 and Gene Fiore like this.
  14. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    The rain curse is broken!! This is for you Ryan...:rofl2:
    Static likes this.
  15. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Was good to see all of you again and some for the first time. I tried to load my pics to my gallery but after finally getting them to sync from my phone they were too large. I give up for now.
