Desert Mavericks.......Sand Box
Discussion in 'Other Automotive Tech & Talk' started by Ryan, Jun 1, 2011.
  1. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    Holy crap...I'm losing it! Of course I meant December...I have corrected that post! Geez...
  2. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    I'm going to provide his number in a conversation to you...look for it soon.
  3. Ryan
    Ryan Ford Addict
    Phoenix Az.
    See you guys in a few weeks. Give me a reason to charge the battery and dust off the car.
    Static and Gene Fiore like this.
  4. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    Yeah...see you all in 4 weeks. Ryan last time we talked you didn't have valid tags on the maverick?
  5. leeinphx
    leeinphx Member
    Show Low Arizona
    1975 LDO
    Loaded the Mav up in Show Low and trailered it down the hill today. Took me a bit to figure out why it wasn't making any power when warmed up, it couldn't even pull itself up onto the trailer... turned out the choke wasn't opening, turned the electric choke adjustment wide open and it drove right on up. Will have to figure that out, but at least each thing I find on that old 200 makes it run a little better. Can't wait to get the 5.0L swap going. That will be in the spring when I take it back up. For now, it just has to run well enough to make the 2 mile drive to the meet :nailbiting:
    Gene Fiore likes this.
  6. Static
    Static Member
    Apache Junction AZ
    1975 Maverick 2 Door
    Ive got one of the fenders off the car now, to fix a hole. I also need to rebuild my steering control valve. Still should make it.
  7. 2mav4u
    Tolleson Az
    Still have lots to do
  8. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    That engine bay sure looks a lot better in the second picture!
    Static likes this.
  9. 2mav4u
    Tolleson Az
    Those a.c. lines are difficult to remove. They keep bending. Might have to cut them off. They need to be replaced anyway
  10. Static
    Static Member
    Apache Junction AZ
    What motor is going in that hole?
  11. 2mav4u
    Tolleson Az
    200ci
    Static likes this.
  12. tbirdz12
    tbirdz12 Member
    Sun Lakes, Az
    69.5 Mav
    Hi Lee
    I replied to your email on the headers but it looks like it didn't go thru. Yes I still have the headers and can hold them for you if you still want them.
  13. Static
    Static Member
    Apache Junction AZ
    Ive been eyeballing those headers. Ive got too many projects going on right now.
    tbirdz12 likes this.
  14. leeinphx
    leeinphx Member
    Show Low Arizona
    1975 LDO
    I couldn't remember if I sent you a message but thought about it every time I saw your ad.
    Quick question, do you think they will they fit past an AOD? It looks like you have a different tranny in your car. If they should fit past, then I'll take them. Haven't had as much time as I want to work on the car so might as well keep spending money on parts :whistle:
  15. tbirdz12
    tbirdz12 Member
    Sun Lakes, Az
    69.5 Mav
    I would think they would since they fit around a non tapered Lakewood Bellh ousing that was for a 94-95 tranny (longer bell housing than normal)
