Desert Mavericks.......Sand Box
Discussion in 'Other Automotive Tech & Talk' started by Ryan, Jun 1, 2011.
  1. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Looks like I'm changing intake manifold gaskets this weekend. Found the reason for my bad idle.
    Static and Gene Fiore like this.
  2. leeinphx
    leeinphx Member
    Show Low Arizona
    1975 LDO
    Sounds good. Send us a reminder with the address as we get closer. I remember my first meet at a small stripmall, is that the place?
  3. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    No it's a different place. The place you are thinking about is at Central and Camelback...Park Central is on Central Ave just north of Thomas Road...so just a bit south of the place you are thinking about.
    Static likes this.
  4. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    Did you get it done?
  5. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Got it changed and still have a vacuum leak. Seams the intake is warped. Time for a new one. Only dual plane manifold I can find with the rear water crossover is the Weiand Stealth. I had one back in the day before the Torker 302 I have now. Seems Edelbrock still hasnt updated the Performer series to have the rear water passage. Im not about to block those off with the aluminum heads and let it start corroding back there.
  6. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    Can the intake be machined to make it right?
  7. leeinphx
    leeinphx Member
    Show Low Arizona
    1975 LDO
    My '70 had a weird vacuum leak. The accumulator canister (tin can) on the passenger side was rotted out on the bottom, top looked perfect looking down on it.
  8. Ryan
    Ryan Ford Addict
    Phoenix Az.
    It could be machined Im sure. If its done right. I had one done a long time ago. Still never sealed. The cost of machining it is about half the cost to get a new one. my cost I can get one for $150, still just $200 retail new.
    I have no vacuum canister on my car. I dont even have a single vacuum hose in the engine bay.
  9. The_Hellcalf
    The_Hellcalf Member
    Phoenix
    1972 maverick
    I drilled and tapped an Edelbrock to use A/N fittings and braided hose. Made the engine looks like a more serious race engine than it was LOL
  10. The_Hellcalf
    The_Hellcalf Member
    Phoenix
    1972 maverick
    Oh I’m new here by the way
    leeinphx and Gene Fiore like this.
  11. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    Glad you joined us! Looking forward to meeting you on Dec 2nd.
  12. 2mav4u
    Tolleson Az
    Well hello all. I'll be there for the meet. Thanks for the text Gene
    Gene Fiore likes this.
  13. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    Cool!
  14. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    Were you able to get it fixed?
  15. The_Hellcalf
    The_Hellcalf Member
    Phoenix
    1972 maverick
    That’s the same day as the hot rod swap meet at Glendale Community College I just realized.
