Desert Mavericks.......Sand Box
Discussion in 'Other Automotive Tech & Talk' started by Ryan, Jun 1, 2011.
  1. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    I was planning on going to the Cruise on Central that night Gene.
  2. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    Oh...did not realize that was the same night.
  3. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    I just found out about it myself. I want to say it was a last minute plan by Nancy Perry. Or possibly a last minute approval by the city.
  4. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    Anyone??
  5. leeinphx
    leeinphx Member
    Show Low Arizona
    1975 LDO
    I'm just around the corner, so may come by. Both my Mavs are in the Show Low shop, but don't have anything else planned that night.
  6. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    Woops...plans have changed and this is cancelled.
  7. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Got a lot done on my Maverick this weekend. Swapped in a new temperature gauge. Changed my intake manifold because the old one warped and had a bad vacuum leak. Changed all hoses. Tried to install a aluminum radiator from Amazon but didnt fit the core support or fan shroud. I could deal with modifying one or the other but it was just too far off. Also reconnected my panel speakers and decided I'd rather cut holes in black panels then have a shitty stereo.
  8. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    Nice...good to hear you are working on the Mav...what intake did you put on it?
  9. Ryan
    Ryan Ford Addict
    Phoenix Az.
    I got a Weiand Stealth. They used to be the only dual plane with a rear water crossover but I just found out even they block the rear passages off. Its nice to be able to idle at 800 rpms again though.
    Gene Fiore likes this.
  10. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    I got my parachute mounted. Does that count?
  11. Ryan
    Ryan Ford Addict
    Phoenix Az.
    It only counts if you plan to use it someday.
  12. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    (y)
  13. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    I'm hoping that I'll never need it! I invested in brakes.
  14. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Those only count if you use those too.
  15. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    Well, there is that.
