Dexron III or type F in rebuilt C4?
Discussion in 'Technical' started by NWMO_Maverick, Jul 3, 2019.
  1. NWMO_Maverick
    NWMO_Maverick Member
    Northwest MO
    1976 Maverick 302, C4
    Hey all,
    The title pretty much covers it. The shop said we could use Dexron III if desired. Easier to find and cheaper. They did say the type F would shift firmer and is often preferred.
    Mild shift kit, etc.
    Unfortunately my son is leaning towards selling, I’m hoping the rebuilt transmission causes him to rethink it.
    Chris
  2. Rick
    Rick G8I operations
    Ocala, Florida
    I would have no problem using DEXIII or VI, it would certanly be better then F
  3. 71gold
    Dexron III will work for the new style clutches, ran it in all my rebuilds.
  4. Krazy Comet
    The friction coefficient is different for F, gives somewhat firmer shifts. Back in day, GM guys often used it in Turbo 350 & 400. Then B&M copied the properties and sold it as Trick Shift.
    Some years back I used F in a slipping '93 Grand Marquis AOD. Along with a B&M electronic shift improver got another 98K mile out of that transmission(died at 131K from a blown pump to case gasket). Also I had a slippy A4LD in a Aerostar, with F was still shifting OK at over 150K miles. Most A4LD were dead by 90- 110K mi.
    F should be changed at approx 25K mi intervals.
  5. Rick
    Rick G8I operations
    Ocala, Florida
    Yep back in the day F was the stuff. For max performance race now, we exclusively use Tractor Supply's Traveller Premium Universal Tran/Hydraulic Fluid. Great stuff, holds up to high temperatures extremely well and extends the life between rebuilds. Shifts very firm and it's only like $40 for a five gallon bucket.
    Rasit, BBMS18 and Krazy Comet like this.
  6. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    On your recommendation I’m going to buy a bucket of TSC’s hydraulic fluid and give it a shot in everything I’ve previously used automatic transmission fluid in (eg snow plow pump, transfer case, and manual transmission’s).
  7. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    I don't have any idea where to find the information now, but years ago I read about the difference between Type F and Dexron. Evidently Type F was designed to slip less as clutch pressure, helping the clutches lock up. Dexron was made to become more slippery under pressure, giving smoother shifts.
  8. 71gold
    I think it also has something to do with the ...clutch material...being different in the newer rebuilt transmissions
  9. Krazy Comet
    I drag raced a '88 T-Bird with stock(does have shift kit) AOD for 10 seasons, used F with no issue.
    Finally blew the 5.0, transmission is still fine.
