Did a bumper swap, question about springs
Discussion in 'Technical' started by redfivexw, Aug 7, 2017.
  1. Krazy Comet
    Has anyone weighed a small bumper setup???
    No chance they weigh zero and 88, 89 - whatever pounds are being removed...
  2. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Better check that scale .. Did you account for the humidity factor ? We are in Florida !
    Cometized
    (Chip)
  3. rthomas771
    Rear bumper weighed 54 lbs without the bolts, guards or mounts (and rust). I'm sure it would tip the scale over 95 lbs with the mounts. The small rear bumper weighed in at 16 lbs with mounting brackets and tag light.
    [​IMG] [​IMG]
  4. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    New springs will have to be cut too.
  5. redfivexw
    redfivexw Member
    Springs done, the new 70-73 springs were smaller, they were not cut and the ride height is spot on, glad I did not cut them,it makes sense that if you install a 70-72 replacement spring along with a 72 bumper that the ride height would be factory. If I had kept the originals they would have needed to be cut. The pic is right after installing, I expect they will settle a bit more as well. Compared to my stock 70 maverick they sit about the same.
  6. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Well your car sits kinda high all the way around, but if that's what you like, it's what you like. At least it doesn't sit like it did with the other springs it had.
  7. redfivexw
    redfivexw Member
    Once i put some bigger tires on (185/75/14 on there now), i think it will look "right". I dont personally go for the lowered look, i like a stock ride look.
