Did Ford ever have all black sport steering wheels in Mavericks or Comets?
Discussion in 'General Maverick/Comet' started by Thomas, Jan 17, 2012.
  1. Dave B
    Like this:
  2. mcmavv
    mcmavv Member
    ontario,canada
    76 mav
    if thats factory
    then mine must be stock.thanks for the reply
  3. 69GT
    69GT Member
    Fresno
    72 Grabber Maverick.
    Let me know if you do. I'll buy one. They really are my favorite steering wheel. I like them better than all the aftermarket ones I have seen so far. I see them every once in a while at the junk yards around here. Maybe I'll pull some if I find em'.
  4. Thomas
    Thomas Member
    Vancouver, BC
    73 maverick
    That's all great info. thanks. I think I'll still bolt it up. Plowing my horn just makes everyone mad at me anyway.
  5. mav6977
    mav6977 Member
    Wichita Falls TX
    various years
    The Pinto's with the Cruising Wagon package (like my 78) used them also.
  6. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    Also granada with the ESS package
  7. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    They can be changed over. I changed my first one over to the correct way.
  8. yellow75
    Tillamook Oregon
    Interesting that you can change them over, I will have to check that out
    Thomas the steering wheel also will not lock when you remove the key as the holes around the outside is what a pin from the ignition cylinder goes into
  9. fan2488
    fan2488 Member
    spring,TX
    I was not able to put the locking plate on mine though.
  10. Acornridgeman
    Wisconsin
    Got any pictures? That would be cool if there was a way to convert them. They look to be all press molded together when they are made and it becomes one solid piece. How did you get it apart without destoying the wheel?
  11. fan2488
    fan2488 Member
    spring,TX
    I did mine a few years back. before I knew about this website. So I didnt take any pictures. If you look on the shaft will see where the are kinda pinched on the shaft. I ground down the the pinched parts only. The every thing lifts right off. I did the same to both wheels. Then changed everything over then tack welded the plate back in place. That wheel is now on my daughtes car.
