Did the Maverick ever have the trunk release in the glove compartment?
Discussion in 'Technical' started by Deanne, Dec 1, 2015.
  1. Hotrock
    Munroe Falls, Ohio
    Deanne,
    Just to make things clear, a Maverick could be outfitted with a trunk release lever. It would have been a dealer installed accessory. It probably was not installed in a glove compartment. More than likely it would have been installed somewhere in the passenger compartment in reach of the driver. Perhaps on the floor near the bottom of the left side of the driver's seat next to the rocker panel ridge.
  2. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
    Also, an electric opener was available as an add on ford accessory and could have been installed at the time the vehicle was ordered. The location of the push button to activate it could have been left up to the owner and thus could have been mounted anywhere.
  3. Dave B
    I have never seen a dealer installed, or factory installed electric trunk opener in a Maverick or Comet in the 27 years that I have been dealing with these cars. Even if it was in the accessory catalogue, it may not have worked in these cars.
    Crazy Larry likes this.
  4. Craig Selvey
    I have never seen one installed either....but I am sure it "could" have been done.
  5. BKelley
    Stone Mountain, Ga
    "72" Comet GT
    One came in my 72 Comet GT... or was there when I purchased the car. Trunk lock mechanism looks like a factory part but has an electric operated plunger.
    Craig Selvey likes this.
  6. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Did you buy that car new in '72? If not, it was likely added later.
  7. BKelley
    Stone Mountain, Ga
    "72" Comet GT
    I did not Larry. But as I posted in post 10, these were available for ALL MODELS beginning in 1970. I suppose the original 70 yr old owner I purchased the car from could have added it a few yrs later?? It sure works great and no modification was made in the truck, bolts holes are spaced identical to the latch mechanism with the electric plunger.
  8. BKelley
    Stone Mountain, Ga
    "72" Comet GT
    In the attached photo from the Master Ford Parts Manual, it shows the electric Trunk lock being available for the 70 up Maverick ( " P" )
  9. Krazy Comet
    Interesting...
    Are there any numbers stamped either in ink or in metal like 7133, 72 02, 72-22 etc(either with or without the space or dash)?? What those are is the code date of mfgr, 7133 would be 1971 week 33, same as 72 02 would be 1972, second week...
  10. BKelley
    Stone Mountain, Ga
    "72" Comet GT
    Tom, there is not... the only numbers present on it can be see in the photo of the lock that I posted. Zoom in on the lock to see what is present.
  11. Hotrock
    Munroe Falls, Ohio
    Sherlock Kelley, you continue to befuddle the disbelievers. Just because a person has never observed something does not conclude it did not exist!!!
    Craig Selvey and BKelley like this.
  12. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Obviously it was an accessory that could be installed, but they never came that way from the factory (unless special ordered). I'd like to have one myself. I get tired of having to use the key every time I want to open the trunk (like if the car is running). I wonder if there are any aftermarket units that will bolt in without modification.
  13. Craig Selvey
    So where is the "button" located?
  14. BKelley
    Stone Mountain, Ga
    "72" Comet GT
    Mine was mounted in the back of the package tray close to the radio.
  15. Craig Selvey
    If you would happen to have a picture of that.....it would be interesting. Thanks
